I created a new ad for the components. I will list them slowly as they are in hundreds of bags. Most of them still new from Farnel in their original bags
200x 0.33nF 275VAC
100x Bridge rectifier 8A, 400V
100x Optocoupler LTV-816
50x Schottky diodes 30CTR060
100x On semi schottky diodes and rectifiers 60A/ 45A TO-220
20x Semi bridge rectifiers 6A 600V
100x mosfets cool mos N-Channel IPA90R1K2C3
40x Schottky diodes 150V 20A TO-220
10x Diode hyperfast 8A, 600V
50x IC PFC CTRLR Transition 10SSOP
125x Capacitor 10uF, 25V SMD
200x Diode ultra fast GPP 1000V 1A SMA
250x Diode zener SOD-323 13V SMD
100x OP Amp Dual 1.1MHz 0.6V/us 8TSSQ
250x Mosfet P CH -30V, -230MA, SDT23
250x Transistors NPN 40V, 0.2A SDT323
100x Diode Schottky SOD-323 SMD
20x Cool MOs N-Channel IPA90R1K2C3
100x IC current mode PWM 2844, MIKIDIP
9x Mosfet N, TO-220, IPP50R299CP
100x Optocoupler TLP281, SMD
7x Diode Schottky 2X20A 25V
25x Fuses 2.5A 250V (they look like capacitors)
230x Relay 12VDC 10A 120VAC
110x Capacitors 200uF 400V
500x Inductor Shield PWR 100uH 10145
30x LCD modules Alphanumeric 16x2 L04-08
30x LCD modules Alphanumeric 16x2 L05-14
200x Radial TD fuse 1.25A 250V
All come from either Farnel, Mouser or Digi something
I will keep updating the list
