I've got a pile of "new old stock" ICs some are interesting others are just glue logic.
Mainly DIL but some SMD.
Quantities are from a quick count so may be off a bit.
For a little more info see the attached .xls
I've no idea what postage would be - would like to send inside Australia only (from Perth).
I prefer to sell in bulk - anyone interested in the lot?[/li]
Send me a PM if you're interested.
EDIT - Reordered for clarity, also I forgot to mention the prices in the spread sheet are the new prices, I'm open to offers of half of that.
~Qty Part # Description
96 MSP430F1121 16 bit Microcontroller
34 PCB80C30BH-3 Micro
39 ADC1205CCJ-1 12-Bit + Sign MuP Compatible ADC
3 AD7533JN DAC 10BIT MULTIPLYING
16 AM7911PC World-Chip FSK Modem
20 UDN2981A 8-Channel Source Drivers 50V -0.5A
13 AT28C256 256K EEPROM
1 CAT28C256P
16 LP365N Micropower Prog Quad Comparator
20 TL074CN Operational Amplifier, QUAD
10 TL084CN Operational Amplifier, QUAD
261 LP324M Micropower Quad Op Amp
19 OP37GP, OP37GN, OP37G Low-Noise, Precision op Amps
30 LM33N
15 SA612AN Double-balanced mixer and oscillator
45 ADC0809CCN 8-bit A/D Converter
100 MM74HC373N 3-STATE Octal D-Type Latch
11 ICM7211AIPL LCD Drivers
180 HI303 Dual, SPDT CMOS Analog Switch
120 LMC7660IN, ICL7660 IC REG SWTCHD CAP INV
207 7663S CPA Regulator
8 MC74HC299N 8-bit Bidirectional Universal Shift Register With Parallel I/o
30 MM74HC139N IC DECODER DUAL 2-4LINE
150 MM74HC4316N IC SWITCH 1X1 16DIP
19 CD74HC123E Dual Retriggerable Monostable Multivibrators
200 MC14028BCP BCD-To-Dec Decode Bin-Octal Decod
16 SN75C1406N Triple Low-Power Drivers/Receivers
8 SN74HC595N 8-Bit Shift Reg 3-State O/P Regs
