Author Topic: FS: AIMS 12kW Pure Sine Wave Inverter Charger 48V 120/240V  (Read 1451 times)
Offline rockdTopic starter
« on: January 29, 2016, 02:44:52 am »
We have 11 AIMS 12kW Pure Sine Wave Inverters available. All brand new, still in their original packaging and shipping containers.
Features
12000 watt low frequency inverter 110/220Vac Split Phase
36000 watt surge for 20 seconds -3x surge capability
Battery Priority Selector
Terminal Block
Marine Coated and Protected
Multi Stage Smart charger 80 Amp
remote panel available
auto gen start
10msec typical transfer time
optional 25W power save mode
8 battery charger settings
Inverter Output Specifications
Continuous Output Power: 12000 Watts
Surge Rating: 36000 Watts (20 Seconds)
Output Waveform: Pure Sine/Same as input (Bypass Mode)
100-110-120Vac / 220-230-240Vac
Nominal Efficiency: >88% (Peak)
Line Mode Efficiency: >95%
Output Frequency: 50Hz +/- 0.3Hz / 60Hz +/- 0.3Hz
Typical Transfer Time: 10ms (Max)
THD: < 10% DC
Input Specifications
Nominal Input Voltage: 48.0Vdc
Low Battery Alarm: 42.0Vdc-44.0Vdc
Low battery Trip: 40.0Vdc-42.0Vdc
High Voltage Alarm: 64.0Vdc
Low battery Voltage Restart: 62.0Vdc
Idle Consumption: 4.16 amps DC
Power Saver Mode Idle Consumption: <0.83 amps DC
Charger Specifications
Output voltage: Depends on battery Type
Charger Rate: 120A
Dimensions
Unit Weight: 174 lbs.
Unit Size L x W x H: 23.3 x 16.3 x 7.9 inches
Shipping Weight: 200 lbs.
Shipping L x W x H 30 x 21.25 x 15.25 inches
Price
$2,000 plus true shipping costs. This is $1049 less than retail, and $600 less than Ebay prices.
