We have 2 like-new AIMS 7kW Modified Sine Wave Inverters. Tested briefly for a prototype but never used past bench testing. Model number PWRIG700024048.
Features7000W max continuous power
Modified sine wave
Power switch LED is also a self test light - Green
Overload fail LED - Red
Over Temperature LED indicator
Over Load LED indicator
1 AC receptacles universal 240 volt
Direct connect terminal block for full load applications
On/off switch
Over Temperature protection
Over Load protection
Thermally controlled fan
DC volt Meter - Input meter
Percent load usage LED bar
5 Externally located re-settable circuit breakers (60amp)
AC output short circuit protection
Aluminum case for optimal cooling
Pre-wired for remote on/off switch
Pre-slotted mounting plate
SpecificationsContinuous output power: 7000 Watts
Surge power capability (peak power): 14,000 Watts
The surge duration is electronically controlled and permits up to 9 seconds while the output is between 7000 and 14,000 watts. During this time the buzzer will sound until the inverter electronically shuts down.
DC input / operating voltage: 42-60 Volts
Output voltage: 240 Volts ac +/- 10%
Output wave form: modified sine wave with phase correction
Output frequency: 60 Hz +/- 1 Hz
Battery low voltage alarm: 42 +/- 0.5 Volts
Battery low voltage shutdown: 41.5 +/- 0.5 Volts
High input voltage protection 60 +/-0.5 volts
No load current: 0.18 A (fan off) 0.66 A (fan on)
Start up AC amps: 58
Continuous AC amps: 29
Full load efficiency: 90%
Auto Cooling Fan Start at 107 degrees F
Full load maximum operating temperature: 154 degree F
AC Output Socket Type: single Type 240 volt plug
Internal fuse protection
Product size (D x W x H): 21.26” X 8.43” X 5.35”
Weight: 31 lbs
Price$800 each, plus $40 shipping in the continental US.
Photos
