Author Topic: FS: Used Test Equipment & Faulty Equipment.. Rigol / Agilent / Tektronix, etc.  (Read 7306 times)
MCSTestEquipment
  • Guest
We have a large list of used equipment that we are looking to sell to clear some space in the warehouse. Images can be provided of any of the equipment that you maybe interested in, just send us a DM and we will get back to you as soon as we can  :)
If you find any of the items that we have below on the internet for a cheaper price, send us a link and we will try and beat it.
All of the items below will be fully checked before they are sent out and come with 14 day returns. Calibration can be provided for an additional cost and all item prices do NOT include VAT (apart from the Rigol products prices, they DO include VAT).
Spectrum Analysers
Agilent - 8590L   9 kHz - 1.8 GHz Portable Spectrum Analyser      2    £400.00
HP - 8594E   10 kHz - 2.9 GHz Spectrum Analyser      6    £650.00
Rigol   - DSA1030A - 9 kHz - 3 GHz Spectrum Analyser      2    £2,280.00
Rigol - DSA832 - 9 kHz - 3.2 GHz Spectrum Analyser      1    £3,348.00 3 Year Warranty
Rigol   - DSA832E - 10 kHz - 3.2 GHz Spectrum Analyser      1    £1,920.00 3 Year Warranty
Rohde & Schwarz - FSL6   9 kHz - 6 GHz Spectrum Analyser      1   Make Offer
Rohde & Schwarz - FSV13   9 kHz - 13.6 GHz Spectrum Analyser   B4, B24   1    £13,000.00
Willtek - 9101   100 kHz - 4 GHz handheld Spectrum Analyser      1    £950.00
Willtek - 9103   100 kHz - 7.5 GHz handheld Spectrum Analyser      1    £2,250.00
Oscilloscopes
Control Company - Traceable Hygrometer   Oscilloscope Monitoring      1    £25.00
Hameg - HMO3054   500 MHz Oscilloscope      2    £2,400.00
Hameg - HMO1002   50 MHz - 100 MHz Oscilloscope      2    £1,200.00
Hameg - HMO2024   200 MHz Oscilloscope      2   Make Offer
Rigol - DS1074B   70 MHz Oscilloscope      1    £552.00 3 Year Warranty
Rigol - DS1074Z-S   70 MHz Oscilloscope      1    £499.00 3 Year Warranty
Rigol - DS1102D   100 MHz Oscilloscope      3    £762.00 3 Year Warranty
Rigol - DS1104B   100 MHz Oscilloscope      1    £660.00 3 Year Warranty
Rigol - DS2102A   100 MHz Oscilloscope      1    £720.00 3 Year Warranty
Rigol - DS2302A   300 MHz Oscilloscope      1    £1,440.00 3 Year Warranty
Rigol - MSO1074Z-S   70 MHz Mixed Signal Oscilloscope      1    £660.00 3 Year Warranty
Rigol - MSO2072A   70 MHz Mixed Signal Oscilloscope      2    £660.00 3 Year Warranty
Rigol - MSO4054   500 MHz Mixed Signal Oscilloscope      1    £5,400.00 3 Year Warranty
Rigol - DS1052D   50 MHz Mixed Signal Oscilloscope      1    £360.00 3 Year Warranty
Tektronix - 2225   50 MHz Oscilloscope      1    £100.00
Generators
Hameg   HMF2550   10 μHz to 50 MHz Arbitrary Function Generator      2    £1,900.00
Rohde & Schwarz - AMU200A   40 MHz Baseband Signal Generator and Fading Simulator
Options: AMU-B11, AMU-B11, AMU-B13, AMU-B13, AMU-B14, AMU-B15, AMU-B17, AMU-B17, AMU-B18, AMU-B18, AMU-K42, AMU-K42, AMU-K43, AMU-K43, AMU-K45, AMU-K45, AMU-K59, AMU-K59, AMU-K62, AMU-K62, AMU-K71, AMU-K71, AMU-K74
1    £500.00
Options: AMU-B11, AMU-B11, AMU-B13, AMU-B13, AMU-B14, AMU-B15, AMU-B17, AMU-B17, AMU-B18, AMU-B18, AMU-K62, AMU-K62, AMU-K71, AMU-K71, AMU-K74
1    £500.00
Rohde & Schwarz - SMB100A   9 kHz - 1.1 GHz RF & Microwave Signal Generator      1   Make Offer
Rohde & Schwarz - SML01   9 kHz - 1.1 GHz RF Signal Generator      1   Make Offer
Rohde & Schwarz - SML02   9 kHz - 2.2 GHz RF Signal Generator      1   Make Offer
Rohde & Schwarz - SMU200A   3 GHz Vector Signal Generator
B10, B10, B13, B13, B14, B15, B17, B81, B82, B103, B203, K40, K62
1 Make Offer
Tektronix - TSG130A   Multiformat Signal Generator      1    £50.00
Tektronix - 2901   Time Mark Generator      1    £100.00
TTi - TGP110   0.1 Hz - 10 MHz Pulse Generator      1    £75.00
Power Supplies
Metrix - AX501   30 /2.5 A Power Supply      19   Make Offer
Agilent - E3632A   120 W Power Supply      5    £500.00
Agilent - E3630A   35 W Triple DC Power Supply      1    £200.00
Agilent - N5749A   750 W DC System Power Supply      1    £1,500.00
Eagle - P008B   13.8 V DC Regulated Power Supply      3    £45.00
HP - 8900D   100 MHz - 18 GHz Peak Power Meter      1    £50.00
HP - 436A   100 kHz - 50 GHz Power Meter      1    £100.00
HP - 6652A   500 W Power Supply      1    £150.00
IFR - 6910   20 GHz Power Sensor      1    £300.00
IFR - CPM20   10 MHz - 20 GHz Counter Power Meter includes IFR Power Sensor 6910 10MHz to 20GHz      1    £600.00
Manson - EP907   90 W Single Output Power Supply      3    £50.00
Rigol - DL3021A   200 W Programmable DC Electronic Load       1    £600.00 3 Year Warranty
Rigol   - DL3031   350 W Programmable DC Electronic Load       1    £720.00 3 Year Warranty
Rigol   - DP712   150 W Programmable Linear DC Power Supply      1    £264.00 3 Year Warranty
Rigol   - DP811   20V/10A OR 40V/5A Programmable Linear DC Power Supply      2    £396.00 3 Year Warranty
Rigol - DP811A   20V/10A OR 40V/5A Programmable Linear DC Power Supply      1    £636.00 3 Year Warranty
Rohde & Schwarz - NGSM 32/10   320 W DC Power Supply      4    £500.00
Rohde & Schwarz - NRP-Z51   DC to 18 GHz Thermal Power Sensor      1    £1,050.00
Rohde & Schwarz - NRV-Z31   30 MHz - 6 GHz Power Sensor      1    £400.00
Rohde & Schwarz - NRP-Z22   10 MHz - 18 GHz Three-path Diode Power Sensor      3    £300.00
Thandar - TS3021S   120 W Single Power Supply      4    £100.00
TTI - PL330   240 W Power Supply      2    £50.00
Shield Boxes
Aeroflex - 4931   RF Shield Box      1    £500.00
Tescom - TC5901A   Pneumatic Shielded Box      1    £200.00
Willtek - 4921   RF Shield Box      9    £200.00
Ramsay - STE2900   RF Test Shielded Enclosure      2    £100.00
Miscellaneous
Aeroflex - 24-40-34   Medium power fixed co-axial attenuator      7    £65.00
Marconi - 2945   1 GHz Radio Communications Test Set      1    £1,500.00
Racal - 6103E   Digital Radio Test Set      1    £200.00
Agilent - 34970A   Data Acquisition / Data Logger Switch Unit      1    £500.00
Agilent - E5515C 8960   2700 MHz Wireless Connectivity Test Set   002,   1    £200.00
Agilent - E5515C 8960   2700 MHz Wireless Connectivity Test Set   002, 003   1    £200.00
Anritsu - CMA3000    Ethernet Tester 10 Gbps - 10 Mbps      5    £300.00
Anritsu - CMA5000   Multi-Layer Network Test and Measurement Platform      1    £300.00
Fluke - PM3384A   100 MHz Combiscope   Z-Mod   2    £150.00
Fluke - PM3384B   100 MHz Combiscope   Z-Mod   8    £150.00
Fluke - 8000A   Digital Multimeter      1    £30.00
Grandway - GW578   Fiber Optic Fusion Splicing Tool Kit      1    £45.00
Hameg - HO3516   350 MHz Oscilloscope Probe      2
HP - 11713A   Attenuator/Switch Driver - Comes with 8494H and 8496H      1    £200.00
HP - 8496B   DC - 18 GHz Manual Step Attenuator      1    £150.00
HP - 8620C   10 MHz - 18 GHz Sweep Oscillator      1    £150.00
HP - 4277A   10 kHz - 1 MHz LCZ Meter      1    £500.00
HP - 8922M   GSM Mobile Station Test Set      2    £150.00
HP - 5314A   100 MHz Basic Universal Counter      1    £100.00
Philips - PM2525   10 kHz - 20 MHz Digial Multimeter      1    £150.00
OKI - HCT-900-21   Soldering System      10    Make Offer
OKI - PS-800   Soldering System      10    Make Offer
Racal-Dana - 9902   Universal Counter Timer      2    £100.00
Rigol - BGA-G1 (BAG)   Rigol Soft Carry Bag      2    £102.00 1 Year Warranty
Rigol - DM3058   Digital Multimeter      1    £384.00 3 Year Warranty
Rigol - VB1080   2GHz - 8GHz VSWR Bridge      1    £540.00 1 Year Warranty
Rohde & Schwarz - ABFS   Baseband Fading Simulator      2    £400.00
Rohde & Schwarz - CMW290 + CMW-Z10   6 GHz Functional Radio Communication Tester   CMW-S600G, CMW-PK290   1    £13,500.00
Rohde & Schwarz - CMW500    Protocol Test
KM012, KM200, KM400, KM401, KM403, KM500, KM550, KM610, KM650, KM651, KM750, KM751, KM800, KM880, KV110, KW400, KW401, KW403, KW500, KW610, KW651, KW750, KW751, KW800, KW880
1 £11,000
KM012, KM200, KM400, KM401, KM403, KM500, KM550, KM610, KM650, KM651, KM750, KM751, KM800, KM880, KV110, KW200, KW400, KW401, KW403, KW500, KW610, KW620, KW650, KW651, KW750, KW751, KW800, KW880
1 £11,000
KM012, KM200, KM400, KM800, KW200, KW400, KW800, KW880, H051B, H052A, H054A, H055A, H090A, H100A, H100A, H110A, H110A, H550B, H570B, H570B, H590A, H590A, H600A, H605A, H612B, H690B
1 Make Offer
Rohde & Schwarz - CMW-Z28   Combiner      1    £1,500.00
Rohde & Schwarz - CMU200   Universal Radio Communication Tester
K21, K22, K23, K24, K65, B11, B21v14, B54v14, B56v14, B68 3.04
1 £400
Rohde & Schwarz - NRP-Z4   USB Adapter Cable      1    £100.00
Rohde & Schwarz - ZVM   20 GHz Vector Network Analyser      1    £12,000.00
Rohde & Schwarz - ZVT8   8 GHz Vector Network Analyser      6    £19,000.00
Schomandle - SWR   Antenna SWR Analyser      1    £400.00
Steinel - HG2510   ESD Safe Heat Gun      10    Make Offer
Tektronix - WFM91D   Handheld Waveform Monitor      1    £300.00
Willtek - 3100   Mobile Fault Finder      6    £500.00
Willtek - 2201   WCDMA Mobile Phone Tester      5    £2,000.00
Faulty Equipment
We also have a list of equipment that are no longer in working condition, all of the items below do not have a set price.
Please make an offer on any of these pieces of equipment and we will get back to you :) we will also provide photographs of the items listed upon request.
Agilent
34970A, 5464D, E5515 x5, N2796A
Anritsu
MD6420A, MT8510B x12, MT8801B, MT8820A, S331D x2, MT8820A
HP
3785 Jitter Generator, 435B x2, 6218B, 6220B, 83220E x2, 8662A, E4412A, E6392A, MA8120E x4
Rohde & Schwarz
ASCU180, ASCU850, CMD50, CMD55 x11, CMD53, CMD60, CMW-CU, CRTU-PU x5, CTS30, TS55, FSV S11 x7, GSM900
Miscellaneous
Beko Ear Simulator, DMC Loopback Oscillator, EXFO FTB-100, First Line FTS831, FIT 70 Installation Tester, Fluke PM3055, Fluke PM3384A x1, IFR 2967, ISO-TECH ISR635, Marconi 2833A x3, Marconi 2965, Racal 6103, Thandor TS3025, Tektronix 2901, Tektronix TDS 520A, Wavetek 9020, WG PF Receiver, Willtek 2201 x8, Willtek 3100 x2, Willtek 4201S x2, Willtek 4403 x2, Wiltron 560, Yokogawa VC3300 x2
« Last Edit: April 08, 2019, 09:06:03 am by MCSTestEquipment »
Offline Critycal
I just want to give a feedback, I bought a Rigol multimeter from them -
very polite and fast communication - very fast shipment to Germany,
thanks again guys!  :-+
Offline blackbird
  • Ooohhhh, what does this button do???
I can second that. Bought two power supplies last month. Good and fast delivery across the North Sea.
MCSTestEquipment
  • Guest
We are happy to take offers on all of the Rigol equipment, they are all new products still in their original packaging with 3 years warranty (apart from the obsolete Rigol products).  :)
Offline Miek
I bought a couple of faulty 66312As from this listing (fixed one already ;D). MCS were great to deal with and they shipped the items fast & very well-packaged. Thanks!
Offline RobBarter
    • Bedrock Systems Ltd
Would love to pickup a faulty Anritsu S331D or R&S CMU200 but even with them being faulty I suspect they would be out of price range for a punt at fixing (my Ham Radio / Radio Astronomy test equipment budget has limits) :(
And as for the CMW500.... v.nice.
Hope to do business with you sometime though, good to have a respected source of used test equipment in the UK.
minimal sig so a single msg doesn't take up the entire page!
Offline Qw3rtzuiop
I bought the broken SMU200A. The package arrived today :-+
Offline Neomys Sapiens
Not among the listed items, but I am in the market for TM500 plugins.
Selected working ones as well as defective, especially if deemed beyond repair and available for cheap.
Online Bicurico
  • Country: pt
    • VMA's Satellite Blog
I got two (broken) CMU200 and can only praise them: fast shipping in excellent packaging and good products.
A pleasure to make business, not so much in the opinion of my wife, though... ("You got yourself another two boxes on the desk???")
PS: I bought them as broken,,, I just re-read my post and thought it sounded unclear.
Offline PA0PBZ
Got one broken (yes, bought as broken) CMU200 from them, paid late Friday, on my desk Wednesday morning packed as a tank  :-+
Offline nctnico
And the SMIQ03B is sitting on my desk... I hope this machine will serve me as good as the Advantest R3131 I bought from MCS many years ago.
MCSTestEquipment
  • Guest
I have given the list a spring clean. All of the items above are available, if you have any interest in any of them, feel free to send me a DM :)
Offline Zucca
  • EE meid in Itali
S331D x2, ..... , S331D x2
typo?
Offline 9aplus
Miscellaneous
What Options or Optional Accessories are included?
Options
Option 1 600 Ω Matching Unit
Option 2 Analog Systems Card
Option 3 High Stability OCXO
Option 4 Parallel Interface †
Option 5 GPIB Interface †
Option 6 Memory Card Drive with real time clock
Option 8 SSB Demodulator
Option 9 Occupied Bandwidth Measurement
Note : Option 2 required when ordering any of the following options 10 to
16
Option 10 NMT Cellular
Option 11 AMPS Cellular
Option 12 TACS Cellular
Option 13 MPT 1327 trunking
Option 14 PMRTEST
Option 15 EDACS™ Radio Test
Option 16 EDACS™ Repeater Test
Option 21 Demodulation Filters
Option 22 POCSAG Decode
Option 23 CCITT Filter ††
Option 24 CMESS Filter ††
Option 30 Bail Arm and Front Panel Stowage cover
Supplied Accessories
AC Supply lead
DC Supply lead
Operating Manual
44991/145 Microphone with PTT
59000/189 Memory Card (128 k)
59000/375 Memory Card (2 M)
43113/021 Battery Pack for 2945A‡
46662/571 ‘Ever-Ready’ Case
46662/616 ‘Ever-Ready’ Case for use with Option 30
54112/163 Hard Transit Case
54431/023 20 dB AF Attenuator (BNC)
46884/728 Rack Mounting Kit
54421/001 BNC Telescopic Antenna
46884/650 Serial port to PC control cable (9 way)
46884/649 Serial port to PC control cable (25 way)
46884/648 RS-232 Printer cable (25 way)
59999/170 RF Directional Bridge
54421/002 (1 to 50 MHz) RF Directional Power Head
54421/003 (25 to 1000 MHz) RF Directional Power Head
54432/012 (50 to 1000 MHz) Wideband Amplifier
46880/079 Service Manual
« Last Edit: March 23, 2019, 04:54:59 pm by 9aplus »
MCSTestEquipment
  • Guest
Unfortunately the 2945 has sold, it was left on the list by accident, apologies.
The following users thanked this post: 9aplus
Offline ramon
  • Country: tw
Hello, sent PM. Thanks
Offline sfalken
I bought the CMU200 and got it now, the communication and delivery was very good and fast. Shipped to Germany with DHL UK (delivered by DHL Express). Very well and securely packed, so thumbs up for MCS!  :-+
Offline daveyk
"HP - 11713A   Attenuator/Switch Driver - Comes with 8494H and 8496H      1    £200.00"
Very old post, so I assume this is gone? Ship to the USA?  Are the 8494 and 8496 good?
Offline davebb
Hi
Have you got any more CMU200 in stock and what configs/options have they got
 or HP 8922M, or any other coms test sets and price and shipped in the uk
Thanks Dave 2E0DMB
« Last Edit: June 26, 2021, 09:04:15 pm by davebb »
Offline Finderbinder
  • Country: lt
Does this equipment list is still available?
