Author Topic: lookin for an isolation transformer  (Read 3872 times)
Offline insomniaaaaaTopic starter
« on: September 14, 2011, 12:17:25 am »
hi all im looking to buy an isolation transformer 240v in and out im in ireland anyone know were to source one
Offline DrGeoff
    • AXT Systems
Re: lookin for an isolation transformer
« Reply #1 on: September 14, 2011, 12:51:38 am »
What VA rating?
It's easy to make one with a couple of identical power transformers connected secondary to secondary, with mains in one primary and isolated mains out the other primary.
Was it really supposed to do that?
Offline SgtRock
« Reply #2 on: September 14, 2011, 01:08:47 am »
Deleted.
« Last Edit: September 14, 2011, 01:42:13 am by SgtRock »
Offline Psi
« Reply #3 on: September 14, 2011, 02:23:54 am »
Deleted.
You realise you can remove the entire post, ya don't need to edit it to say "deleted"
Its two buttons to the right of the Quote button.
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #4 on: September 14, 2011, 03:53:53 am »
Transformers are heavy, its not worth shipping them.
Ask your question at any local electrician, he will have the answer.   :)
Offline Zero999
  • 0999
« Reply #5 on: September 14, 2011, 05:12:16 pm »
What VA rating?
That will work but the efficiency and regulation will be severely reduced and the size doubled.
Offline vk6zgo
« Reply #6 on: September 26, 2011, 02:27:52 pm »
There were a lot of these used in TV Service companies over the years,so there should be quite a few floating around,if not in Ireland,maybe in the UK.
Many of the small TV Service companies have folded up or gone into other things.
Some may still have isolation transformers on a shelf somewhere,gathering dust.
Ask around locally.
If there used to be a TV repair shop in your area,you might get your hands on one cheaply.
VK6ZGO
