Using freon is a good idea in heat piping, you know, a air-conditioner depends on the coolant's rapid evaporation to cool the surrounding air down and they use pipes to transfer the coolant, so in heatsinks they are called "heat pipes" because all they do is pipe heat with a coolant (What's the name? I can't remember it)
But in most heatsinks that aren't too high power they just use a liquid that doesn't evaporate i think
The reason AMD was able to efficiently pipe 300W of heat around their dual-GPU monster is due to something called a "vapor-chamber" (which essentially is a heat pipe filled with very volatile liquid (I mean something like the stuff they use for aircons?) without going over 80C in such a form factor
