Hi
tell me were you buy your part
digi-key was 18$ only for The Mega2560
Mega64 13.79$
saelig was 15.76$ for ulfat + UPS shipping
MAX3421E was 14.5700$ (sorry make typo on first post PN)
and so on ..
so sorry i build that board since several year and batch of 12 cost near 1300$ in part
ok i remove the MAX3160CAP and the LM22670MRE-5.0CT-ND
but that my last order for make 12 on that board .. (missing on that Ulfat and AT45DB161D )
1 25 MAX3160CAP+-ND IC TXRX RS232/485/422 20SSOP 25
Immediate 0 10.83680 $270.92
2 12 644-1037-1-ND CRYSTAL 16.000000 MHZ 8PF SMD 12
Immediate 0 0.72400 $8.69
3 12 644-1033-1-ND CRYSTAL 10.000000 MHZ 8PF SMD 12
4 12 644-1034-1-ND CRYSTAL 12.000000 MHZ 8PF SMD 12
5 12 576-1152-ND IC REG LDO 250MA 5V 0.5% SOT223 12
Immediate 0 1.86000 $22.32
6 12 296-9845-1-ND IC NAND GATE 2-IN SOT-23-5 12
Immediate 0 0.46000 $5.52
7 12 576-2163-ND IC USB SWITCH DUAL 8-SOIC 12
Immediate 0 1.58000 $18.96
8 12 296-14437-1-ND IC LDO REG 3.3V 250MA SOT223-6 12
Immediate 0 2.35000 $28.20
9 12 296-14429-1-ND IC LDO REG 1.8V 250MA SOT223-6 12
10 12 296-16845-1-ND IC BUS TRANSCVR 2BIT N-INV SM8 12
Immediate 0 0.81000 $9.72
11 12 BZT52C3V3-FDICT-ND DIODE ZENER 3.3V 500MW SOD-123 12
Immediate 0 0.26300 $3.16
12 200 F2226CT-ND VARISTOR TVS MULTI 9V 30A 0603 200
Immediate 0 0.44730 $89.46
13 12 102-1152-ND BUZZER 2.048KHZ 12MM PC MOUNT 12
Immediate 0 0.83000 $9.96
14 12 445-1975-1-ND INDUCTOR SHIELD PWR 10UH 10145 12
Immediate 0 1.20800 $14.50
15 25 SK34A-TPCT-ND DIODE SCHOTTKY 3A 40V SMA 25
Immediate 0 0.44900 $11.23
16 12 ATMEGA640-16AU-ND IC MCU AVR 64K FLASH 100-TQFP 12
Immediate 0 12.17000 $146.04
17 25 TLP172GFCT-ND PHOTORELAY MOSFET OUT 4-SOP 25
Immediate 0 1.86560 $46.64
18 12 ED90062-ND CONN RECEPT USB TYPE A PCB 12
Immediate 0 1.45500 $17.46
19 12 WM23809-ND CONN HEADER 20POS 4.2MM VERT TIN 12
Immediate 0 2.51000 $30.12
20 12 A9AAT-1306F-ND FLEX CABLE - AFE13T/AF13/AFE13T 0
Immediate 12
Value Add 3.12100 $37.45
21 12 MAX3421EEHJ+-ND IC USB PERIPH/HOST CNTRL 32TQFP 12
Immediate 0 13.35000 $160.20
22 12 LM22670MRE-5.0CT-ND IC REG SWITCH BUCK 3A 5V 8PSOP 12
Immediate 0 5.82000 $69.84
23 12 ATMEGA2560-16AU-ND IC AVR MCU 256K 16MHZ 100TQFP 12
Immediate 0 18.53000 $222.36
24 25 296-19807-1-ND IC RS232 3V-5.5V DRVR 28-SOIC 25
Immediate 0 1.53120 $38.28
Subtotal $1,306.61
