Author Topic: Wanted: ERSA X-tool only  (Read 2622 times)
Offline AlexTopic starter
« on: July 10, 2018, 09:59:04 pm »
I am looking for an Ersa X-tool desoldering iron. The iron only, not the station.
Thanks,
Alex
Offline sn4k3
  • Country: pt
Re: Wanted: ERSA X-tool only
« Reply #1 on: July 11, 2018, 06:59:17 pm »
Thanks,
Alex
If you are looking for new unit you can find them here:
https://www.ersa-shop.com/ersa-entl%C3%B6tkolben-xtool-vario-p-12062.html (Vario!)
https://www.ersa-shop.com/ersa-entl%C3%B6tkolben-xtool-p-2746.html
They are expensive :(
« Reply #2 on: July 11, 2018, 07:11:46 pm »
Yup - although not too bad considering the full system is ~1000 Euros.
I will keep it mind, many thanks.
Alex
Offline KaneTW
« Reply #3 on: July 11, 2018, 07:49:54 pm »
Are you intending to use a separate compressor for the vacuum supply?
« Reply #4 on: July 11, 2018, 07:57:32 pm »
Yes - have you got an x-tool?
Alex
Offline KaneTW
« Reply #5 on: July 11, 2018, 09:27:36 pm »
No, but I'm considering buying one eventually. I have an i-con 2V station, so I'd need a vacuum compressor and the iron.
Online wraper
  • Country: lv
« Reply #6 on: July 12, 2018, 12:41:53 pm »
I would suggest to not buy old X-tool. It sucks for working for prolonged time. Handle simply heats up really fast and becomes impossible to handle. Also you need to buy replacement containers for solder. But the worst part there is also a small filter after container which gets wet from flux fumes really fast and suction force drops tremendously. It's OK for occasional component removal. But if you need to deslolder a lot of pins, like x16 PCI-E connector, it becomes a real problem.
The following users thanked this post: CM800
Online wraper
  • Country: lv
« Reply #7 on: July 12, 2018, 12:45:32 pm »
Certainly buy x-tool vario, not the old one.
« Reply #8 on: July 12, 2018, 01:14:00 pm »
Roger that, thanks for the tip.
Alex
Online wraper
  • Country: lv
« Reply #9 on: July 12, 2018, 01:33:20 pm »
Alex
Although if you have non V/vario station, x-tool vario is not supported.
Offline KaneTW
« Reply #10 on: July 12, 2018, 02:47:10 pm »
Yeah, I wasn't even considering the old one. It looks super unergonomic.
