Author Topic: WTB(UK) RF DC Block and cables  (Read 2566 times)
Offline trevwhiteTopic starter
« on: September 25, 2017, 07:40:26 pm »
Hi
I have a SSA3021X on order along with a TEKBOX probe set. I am new to using a Spectrum Analyser and I read that a safe thing to do is use a DC Block to protect the SA input. I found one in RS but it was over £50. I found one on ebay, it was £5. I was wondering what is the normal price for a DC Block and where can I buy one that I can trust?
A recommended seller of RF cables and accessories that I might need for the future would be helpful as well thanks.
Thanks
Trev
Offline CJay
Re: WTB(UK) RF DC Block and cables
« Reply #1 on: September 25, 2017, 07:49:05 pm »
The following users thanked this post: trevwhite
Offline tautech
« Reply #2 on: September 25, 2017, 07:54:05 pm »
I worried about this too when I got my 3032X.
I bought the UKitSSA3X accessory kit as a starter and except for some more adapters and some more SMA cables haven't needed anything else. Those Siglent supplied cables are characterised to 6 GHz.
http://www.siglentamerica.com/prodcut-fj.aspx?id=5113&tid=227&T=2
The SSA's have an input rating of +/- 50 VDC max and Over Voltage warning protection that I've only activated once when I had the inbuilt attenuator set to Off. User error.  :palm:
Research when I was looking indicated all the DC blocks available had the same 50V rating and I saw little need to double this up. In the 3000X thread there's some input from members about what accessories are useful.
Starting here:
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/msg990874/#msg990874
« Last Edit: September 25, 2017, 08:55:00 pm by tautech »
Offline 4CX35000
« Reply #3 on: September 25, 2017, 07:56:15 pm »
« Reply #4 on: September 25, 2017, 07:59:03 pm »
Great, thanks all.
I also would like to do some tuning measurements with a RBSSA3X20 but I watched a review that said this kit was not particularly good. I think I read somewhere else that you can make them/buy them from Ebay cheap? Anyone had good experience with a cheap kit?
Trev
Offline tautech
« Reply #5 on: September 25, 2017, 08:09:18 pm »
Great, thanks all.
Trev
Spec says they're rated to only 2 GHz so maybe that's why they didn't get a good wrap.  :-//
The bit I like about them is there's no additional cabling required, they connect directly to the TG and RFin ports.
But yes, bought on their own (no SW option) they ain't cheap.  :scared:
There's a pic of one I got for a customer in the 3000X thread....comes in a nice padded soft case.  :)
« Last Edit: September 25, 2017, 08:44:22 pm by tautech »
Offline 4CX35000
« Reply #6 on: September 25, 2017, 08:14:26 pm »
You can buy reasonable second hand couplers on eBay for reasonable prices which will cover the frequencies you require. Also remember there are plenty of Mini-Circuits couplers on eBay which for fine for measurement purposes, once you calibrate it with the tracking generator.
Offline tautech
« Reply #8 on: September 25, 2017, 08:37:11 pm »
« Last Edit: September 25, 2017, 08:43:37 pm by tautech »
Offline 4CX35000
« Reply #9 on: September 25, 2017, 08:54:51 pm »
DC Block is nothing more than a capacitor in series with the spectrum analyser. You can buy those cheap versions if your certain the DC voltage your working with is reasonably low; but it also comes down to the performance regarding losses, frequency range and max DC voltage the capacitor can withstand. From what I can see you have no idea of the performance, as you have no idea who manufactured them (No data sheet), whilst the products from other manufacturers like JyeBao, Minicircuits and so on, you know the exact performance and max DC voltage of the DC Block.
http://www.jyebao.com.tw/upload/DC-AMAF0-5G100V50.pdf
https://ww2.minicircuits.com/pdfs/BLK-18+.pdf
