I am looking for the below parts. I would prefer the items to be shipped from EU due to high import taxes.
- HP/Agilent BNC (F) to SMB (F - right angle) (used in E4406A for I/Q
ports on front panel, possible part numbers 1250-0870-01 or 8120-5055)
-> 2 pieces
- HP/Agilent test equipment feet (possible part numbers 5041-8801 or
5041-9167) -> 5 pieces (2 of them should have the metal part for the
front tilt of the equipment)
- HP/Agilent side handle for E4406A complete with screws, not sure about
compatibility with other TE but I want to use it on my E4406A -> 1 piece
but I can buy also a pair and have one as spare
- HP/Agilent 08757-60058 Log Amplifier A7 -> 1 piece
- HP/Agilent 08757-60113 Keypad panel with 4 channel buttons, must have
the DS12887 clock chip on it -> 1 piece
- NI GPIB Extenders, possible part numbers NI 181638-01B or similar
HP/Agilent -> 7 pieces
- HP/Agilent SMA to SMA semi-rigid coax used in the RF Plugins for 8350B
like 83540A/83545A with attenuator. The part I need is from Output port
of the attenuator to the front Type-N bulkhead. I cannot find the part
number for this but attenuator and front bulkhead is installed in the
position on most of these 835xx RF plugins -> 1 piece
- HP/Agilent 64MB Flash board for E4406A. From what I researched it will
probably fit also the one from E4440 PSA -> 1 piece
- HP/Agilent 5063-9262 RAM memory board for E4406A VSA or E4440 PSA.
Should work from both since the CPU board is the same -> 1 piece
Looking for offers.
Thanks!
