Hi all,
I have an old model (same product, different case) Picoscope 2208 that I rarely use (I personally dislike not having the UI of a bench top scope, but it is very small and handy), with one TA131 250MHz (10MHz 1:1) probe. It is a 200MHz USB scope with signal generator and external trigger (max 20v input, 5v sig gen output) and two channels. I know the consensus on this forum is that PC based scopes aren't great, but if you need the higher bandwidth, small size and ease of extracting data, they can be great; also, Picoscopes are some of the best around in terms of software (same from the low end to the big £££ scopes).
I would like a low range scope in the bench top form factor to trade for this. Something like a decent Siglent, maybe a Rigol if anyone has one, if you have anything else PM me and I'll definitely consider other brands. I am looking for ~100MHz bandwidth, although 50-70MHz might be alright. Keep in mind that these Picoscopes do go for quite a lot (the 2206 at 50MHz goes for around £500 on eBay), and mine is as new in original box; the probe is also quite expensive. I do not mind if it is used, but in decent condition, and any probes you can include would be great. Would definitely consider a MSO as well.
Hopefully someone is in the market for a USB scope!
Regards,
Jack
