Author Topic: 0201 practice board?  (Read 2212 times)
Offline pcm81Topic starter
« on: September 19, 2025, 09:26:48 pm »
I see a bunch of 1206 0804 and even some 0603 solder practice boards on Amazon. But what i am looking to practice soldering with is smaller stuff... does anyone know where i can get 0201 or atleast 0402 practice boards? I see very cheap boards on ali express, but they are also for larger package size...
Thanks ahead
Offline exe
  • self-educated hobbyist
Re: 0201 practice board?
« Reply #1 on: September 19, 2025, 09:44:03 pm »
There are not that many for 0201. You can make your own. Anyway, a suggestion: https://www.tindie.com/products/makersbox/smd-challenge/
Offline UnijunctionTransistor
  • Ohms Law: Resistance is futile.
« Reply #2 on: September 19, 2025, 09:47:29 pm »
My two yen opinion;
Because 0402 and 0201 are too small to be hand-soldered reliably by the vast majority of hobbyists, and these dimensions are better suited to be installed by precision pick and place machines.
And I know, there are people who can actually hand-solder 0201 devices, and have the videos to prove it. Here is one;
https://youtu.be/57bntqxfSFY?si=jg4-QYUF5jwr4MX1
The following users thanked this post: pardo-bsso
« Reply #3 on: September 19, 2025, 10:03:53 pm »
My two yen opinion;
I am not a vast majority of hobbyists :)
I have a microscope.
Been practicing replacing a 0.25mm pads on QFP with moderate success so far.
Offline thm_w
  • Non-expert
« Reply #4 on: September 19, 2025, 10:24:48 pm »
The most impressive part is that the tip is completely wrong, its massive.
With C115 and a microscope, its much easier.
« Reply #5 on: September 20, 2025, 01:57:46 am »
Absolutely! I like bent conical in 115 as well as a blade on 115/210 or 245. If you let the tip to oxidize on purpose and then just clean the very tip of it, you can be very accurate.
The following users thanked this post: MathWizard
Offline Simmed
« Reply #6 on: September 20, 2025, 02:19:36 am »
check this 1 out  :P
Offline Siwastaja
« Reply #7 on: September 20, 2025, 05:37:40 am »
Just do a real project with a lot of 0201. Bonus points for promising it finished to someone in dire need of the board. Necessity is a good motivator.
The following users thanked this post: exe
Offline EPAIII
« Reply #8 on: September 20, 2025, 06:04:40 am »
Two words:
Hot Air.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Online SiliconWizard
« Reply #9 on: September 20, 2025, 04:10:04 pm »
One thing you have to be careful with 0201 components: they are so tiny that they have ultra-low thermal mass. What it means is that you'll literally "vaporize" them if you apply too much heat with a soldering iron.
So either use a very fine tip and a low-power soldering station, and caution, or preferably use some solder paste and a hotplate for "manual" soldering.
Offline MathWizard
« Reply #10 on: September 21, 2025, 05:26:42 am »
I use chisel tips and I usually burn/melt the edges of SMD LED's w/ my iron, I need to practice that.
I've tried 04xx on a GPU, and luckily it worked. I don't think I used a microscope for that.
I should try something really small on an old junk PCB, with the microscope. And rememeber Obi-wan Kenobi saying to Trust the Force, and use the microscope. Or maybe using the force would be doing it w/o the MS. But I mean moving my hand, based on what I see on screen, that's still tricky.
« Reply #11 on: September 21, 2025, 01:34:28 pm »
I'd be curious to see someone manage to hand solder 0201 without magnification.
