Looking for very high value resistors- 1 TOhm ideally with a 5kV rating, <=1/4w fine, <=250 ppm/C and decent voltage coefficient. I can stack a couple but the capacitance quickly gets out of hand. I plan to air wire this stuff on Teflon standoffs but don't want to resort to anything more exotic. The application is high impedance voltage measurement around 2kV nominal- consulting job.
Stackpole, Murata, and Ohmite make the kinds of parts I want but they appear to be unobtanium or are $100/unit. Victoreen, Cleveland used to make parts like this but they got bought by Fluke and I can't find them anymore- maybe internal use only. New Old Stock in decent shape would be fine if they can provide 100'+s. One time build of a few hundred units is most likely. I've looked on Ebay and see some very old NOS Russian/Bulgarian beauties from early cold war, probably 70 years old. Qtys are low but am asking suppliers, will buy some to test with. The Bulgarian units are sealed in glass, tolerances are loose (5-10%), no specs other than ohms and quantities are limited (so far). Does anyone have any experience with these- photo below. They're about $5 in singles which is in the ball park. I used to get these from Victoreen for about $1.
Any other suppliers, leads or ideas would be appreciated.
