It’s just increased a lot lot in personal value now it works
Not first go, but after fixing a mistake in installation (not this module itself) swapped SPI clock and data out,
and also the crystal oscillates intermittently when set up with the 33pF cap values in the data sheet example.
It works reliably now I have only disconnected one of them from ground which surprises me.
I was going to go all the way to swapping both for 22pF, but the first disconnection I made had it working reliably
Now it also means I should spend the money on good goop since I’d really get into Eagle CAD more than do this again,
So I’ll look into the MG Chemicals, so long as it’s not an unreasonable minimum to buy.
