I'm also having trouble saving waveforms on my scope. the instructions are a bit vague and i'm getting rather lost, I take it that bitmaps are the best format to save in
Best depends on what you want to use it for. Here's how to save waveforms:
1) Press Storage
2) Press soft key 1 and select one of:
Waveform (data file)
Setups (the current scope settings)
Bit Map (Picture of the scope screen)
CSV (Comma delimited file)
Factory (reset to factory defaults, not what you want)
3) Select any options (not sure what Para Save does on bitmaps? Maybe does or does not save the parameters?)
4) Choose internal or external
5) If Internal use the multipurpose knob to pick one of the 10 slots and then hit load/save/delete. I think (S) means set and (N) means empty. As far as I know you can't change the names.
6) If external it takes awhile on a big drive for the file browser to come up.
7) Pick New File (unless you really want to save over an existing file)
Use the X soft key and the multi knob to get the file name looking like you want.
9) Hit save.
Does that help?
Hey I noticed something. On 2.02SP2 or whatever if you held a button down for a few seconds it would pop up a help screen on that button's feature. In 2.04 that seems to be gone? Or is there some other reason that quit working I wonder? It still looks like it is trying to load something the first time but it doesn't work.
