I'll throw my hat in the ring for Metcal, my experience with the station of theirs we have at work is phenomenal. I couldn't be more pleased. But then that's probably because we have a USD 500+ metcal. We also have a Saike 852d+, in the USD 110 range, that I have no complaints about and that includes a hot air gun. I'd recommend both, although I admit I usually use the Metcal.
At home, my station is a Weller WESD51, which can be had new for around USD 200 high end, so in the 120 pounds range. Amazon US actually has it for $130, so not even that much. I absolutely love it, and actually just bought one on behalf my main student group. The only point of caution that I'd make about the weller is that the finest tip pitch you can get for it is .4mm, which I find to be small enough to get by even for the finest work I've done (8/10MSOP packages, pin spacing .5mm), but you can get still finer tips for the others.
