EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
are jfet drain and source interchangeable?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: are jfet drain and source interchangeable? (Read 5587 times)
vixo
Regular Contributor
on:
June 10, 2020, 08:56:02 am »
I use 2n3819s sometimes but there are two pinouts - fairchild is different to ON semi, with the drain and the source being changed round. Does this matter? I always thought No, but I was very confused in the past when i bought a few which didnt work. I put this down to the fact they were the wrong pin out, by I have since learnt that there are some fakes of these floating around...
should it make a difference?
Logged
Yansi
Super Contributor
Country:
Re: are jfet drain and source interchangeable?
Reply #1 on:
June 10, 2020, 09:03:03 am »
Shouldnt make a difference as far as I know.
Logged
madires
Super Contributor
Country:
A qualified hobbyist ;)
Reply #2 on:
June 10, 2020, 09:50:23 am »
Not really, it's fine in many cases. But there are also some JFETs where it matters. You can find the real source by measuring the gate-source and gate-drain capacitance. The gate-source capacitance will be much lower.
Logged
Kleinstein
Super Contributor
Country:
Reply #3 on:
June 10, 2020, 10:07:55 am »
With many JFETs there is no real difference between drain and source. So a circuit should still work if "reversed", as the variations between units are larger than from reversion the chip.
Especially JFETs for high frequency use can have intentional asymmetry and better performance when used the right way around. AFAIK the gate to drain capacitance should be the smaller one in most applications - so it could depends on the circuit which way is better.
The 2N3819 seems to be asymmetric with a low Crss (gate - drain).
Logged
SiliconWizard
Super Contributor
Country:
Reply #4 on:
June 10, 2020, 02:58:25 pm »
As said above, not all discrete JFETs are symmetrical (from experience it's even slightly uncommon, but YMMV.) In any case, check the datasheet, although it's not always easy to derive that information from some datasheets.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
