The way I read it is that JPortici has a different problem.
Ah, i haven't replied in a number of threads because the quote button doesn't work anymore and i don't want to bother doing it manually.
probably for the best?
I interpret "Not replied due to the quote button not working" as clicking on the regular "Quote" button above someone else's post and enter the normal editor that way. Not using the quick modify editor, where you would have to use the "Insert Quote" button.
Edit: Yet he did manage to use a quote in message 179.
because it works in the full editor
the issue i'm seeing is in the quick editor, the quote button on the upper right of any post.
But i'm not going to go to the full editor to quote a post from three pages earlier, that i have to find in the list of recent replies, which isn't there anyway.
Here the quote button has stopped working the moment the quick editor was reverted from new to old
edit: just for kicks, i tried in safari, that i never use because it's a shitty browser, so i don't have ublock installed, or any other plugin. same issue: hit the quote button of upper right of post, forever loading.
