Author Topic: Bad transformer?  (Read 1926 times)
Offline SiliconArtistTopic starter
    • My hobby blog
Bad transformer?
« on: November 16, 2025, 10:54:55 am »
      I bought a new 200VA 230/230V transformer but I think it is something wrong with it. I draws ~370mA without a load (I connected a 100 \$\Omega\$ resistor in series and it drops 37V on it). It happens the same if I supply the secondary side. Both primary and secondary have 8 \$\Omega\$. The magnetization current can be so high?!
     The transformer has an electrostatic shield. Could it be shorted in a way that it behaves like a continuous loop?
https://adajusa.es/es/transformadores-monofasicos/5150-transformador-200va-230230vac-ultra-aislamiento-ip-20-8435532851509.html
Offline Sorama
Re: Bad transformer?
« Reply #1 on: November 16, 2025, 11:13:03 am »
What is the reasoning behind putting a resistor in the primary??
Of course you will have a voltage drop across it.
    • My hobby blog
« Reply #2 on: November 16, 2025, 11:18:34 am »
I added the resistor because the transformer was making strange noises. Like an intermittent buzz. So I wanted to have some current limitation in case there is a short inside. This is just for testing, I will remove it of course. But in this way I discovered the large voltage drop across the resistor. Without a load.
Offline coppercone2
  • √Y√... 📎
« Reply #3 on: November 16, 2025, 11:19:55 am »
it should not increase the standby draw of the transformer to have a resistor there
Offline Sorama
« Reply #4 on: November 16, 2025, 11:26:23 am »
Yes it should, given the 8 ohm and thus a voltage divider.
Edit; not increase the current, but change accordingly.
« Last Edit: November 16, 2025, 11:53:21 am by Sorama »
Offline Benta
« Reply #5 on: November 16, 2025, 11:31:59 am »
The magnetizing current is plausible though high for a 200 VA type. It's almost purely inductive, so it costs you nothing. Modern transformers are run very close to saturation (to save copper and iron).
Offline Xena E
« Reply #6 on: November 16, 2025, 11:39:02 am »
Does it overheat?
You can ring test the windings to check for a shorted turn.
Offline RoGeorge
« Reply #7 on: November 16, 2025, 11:59:51 am »
By its size, looks more like 20VA transformer rather than 200VA.  What is the size of the magnetic core?
There was an empirical formula to approximate the required section of the magnetic core by the total power.  Vaguely recall
S = 1.5 * sqrt(P)
Where
- S is the core section in square centimeters (by core section meaning only the metal encircled by the coils, so only the middle leg of the E shaped core)
- P is the transformer power, here 200VA
For example, for a 200VA transformer, the expected core section should be about 20cm2 or more, so the thickness of the E stack multiplied with the width of the middle leg of a single E (all in cm) should be about 20 or bigger for a 200VA mains transformer.
Most probably I recall that formula wrong... ::), better search online for mains transformer design, particularly for the step where the section of the core is estimated starting from the desired total power.
The no load current seems large to me, I guess that is because the magnetic core enters into saturation (too much voltage).  Seeing USA mentioned on the label, makes me wonder why would they sell 230V transformer in USA, where the mains AC is 110V.  Maybe that transformer was mislabeled, and it is in fact a 110V transformer?  :-//
« Last Edit: November 16, 2025, 12:25:40 pm by RoGeorge »
    • My hobby blog
« Reply #8 on: November 16, 2025, 12:02:24 pm »
Does it overheat?
What is ring test? Is the measuring of the Q of each winding? My transformer has Q=21 and inductance of 2H @ 100Hz for both primary and secondary. Are these reasonable values?
I removed the primary resistor and added a 4.6k load on the secondary. The current in the primary was 0.44A and in the secondary 0.05A. Secondary voltage was 225V. There is a huge difference between the two currents. Is this normal for a 1:1 transformer?
« Last Edit: November 16, 2025, 12:11:06 pm by SiliconArtist »
Offline Xena E
« Reply #9 on: November 16, 2025, 12:07:33 pm »
It says "Por Adajusa" not USA, it's the distributors name.
    • My hobby blog
« Reply #10 on: November 16, 2025, 12:09:37 pm »
S = 1.5 * sqrt(P)
Where
The thickness of the laminated stack is 37mm. I can't measure more because it is covered in a resin. But according to your formula the middle section should be 57mm in width. And this is not possible given the total width of the core (95mm).
I think I will return it, it is something fishy with this transformer
Offline Xena E
« Reply #11 on: November 16, 2025, 12:12:01 pm »
Does it overheat?
I removed the primary resistor and added a 4.6k load on the secondary. The current in the secondary was 0.44A and in the secondary 0.05A. Secondary voltage was 225V. There is a huge difference between the two currents. Is this normal for a 1:1 transformer?
A ring test is to see if the transformer I'd being damped by a shorted turn or similar... I'll try to find a link to an example... back in a mo!
« Last Edit: November 16, 2025, 12:17:47 pm by Xena E »
Offline RoGeorge
« Reply #12 on: November 16, 2025, 12:33:24 pm »
My formula is most probably wrong, Ive just strikeout that formula moments ago in my previous post, sorry for that, but the idea still stands.  Find out the area and deduce the max power.  Better find some online calculator.
Usually the width of middle leg of the E core is a certain ratio of the E size, see if you can identify the width of the middle leg from the datasheet (random example for mains transformers E+I core materials/sizes https://www.lodestonepacific.com/wp-content/uploads/2021/08/Bobbin-E-Core-Lam-Cross-Reference.pdf )
« Last Edit: November 16, 2025, 12:47:18 pm by RoGeorge »
    • My hobby blog
« Reply #13 on: November 16, 2025, 12:59:51 pm »
Good idea! According to that table the width of the middle section is 31mm. This result in a cross section of 31 x 27 = 1147 mm^2. Depending on the source, for 200VA the section should be between 1600 to 1900 mm^2 ...
Offline tooki
« Reply #14 on: November 16, 2025, 01:15:28 pm »
Also, a reminder that the voltage in USA has been 120V since the 1950s. It’s not 110V now, and hasn’t been for a very long time.
Offline Zero999
  • 0999
« Reply #15 on: November 16, 2025, 01:34:59 pm »
It's obviously bad. Return it.
Did you read the specification linked to in the original post?
2.9kg seems about right for  200VA transformer.
    • My hobby blog
« Reply #16 on: November 16, 2025, 07:45:27 pm »
I changed my mind, I think the transformer is fine. I let it run for 1h with a 125mA DC load (after rectification) and it is barely warm. That large primary current I measured must contribute only to reactive power.
The following users thanked this post: RoGeorge, Xena E
Offline Benta
« Reply #17 on: November 16, 2025, 08:38:49 pm »
Q.E.D.
The following users thanked this post: Xena E
Offline soldar
« Reply #18 on: November 25, 2025, 08:47:37 pm »
Everything in that transformer looks perfectly good to me, magnetizing current included.
