Yeah,back in the day,we used to sell well made ones at my first job-----I never liked them much,myself,but they were properly designed,with correct high voltage construction of the resistor,etc.
Ours were made in Germany,& had the maximum voltage rating clearly written on them.(380V)
They are meant to be used by people with some idea of what they are doing---not morons!
The proper tool to check mains voltages is a DUSPOL (http://de.benning.de/en/corporate/products-services/testing-measuring-and-safety-instruments/testequipment/duspol-facts.html). Fluke got a similar tool.
When we sold them,circa 1960,such high tech stuff was a distant dream.
Electricians used them mainly as a quick check that Active & Neutral were present,& on the right pins in sockets,(although it was only a "suggested" orientation in Western Australia till the '70s).
For serious work,they used an analog multimeter.
Why I said I didn't much like them,is the possibility of the neon failing due to dropping the tool,where the next test would show a false "safe".
It shouldn't happen with Electricians ,as they are taught to test their tester each time in a known active point (for multimeters,too!),but they can get a bit lax with this-----& the rest of us will probably just assume our test equipment is OK.
