EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
BPW41N it is a linear sensor ?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: BPW41N it is a linear sensor ? (Read 1160 times)
harrysmith
Contributor
Country:
on:
September 24, 2020, 03:18:44 pm »
hello community. I hope you are well
I would like to know is that the BPW41N sensor is a linear or non-linear sensor with justification. thanks
Logged
SeanB
Super Contributor
Country:
Re: BPW41N it is a linear sensor ?
Reply #1 on:
September 24, 2020, 04:18:20 pm »
Quite linear if used in a current source mode into a virtual ground at an opamp input, and,like any photodiode, not linear in voltage source mode, though running it with a bias voltage probably will be reasonably linear.
Datasheet here,
https://www.vishay.com/docs/81522/bpw41n.pdf
so yes it is reasonably linear within a range, though low light and bright light levels is going to make it non linear at the high end, and noisy at the low end.
Logged
Halcyon
Global Moderator
Country:
Reply #2 on:
October 08, 2020, 09:43:34 am »
Please stop posting the same questions in individual threads. Use the existing thread you have. You are on notice.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
