Author Topic: Breaking News: Over-Unity Reactionless Generator Invented In India  (Read 21908 times)
Offline johnlsenchakTopic starter
  • js@antihotmail.com
    • paypal.me/johnsenchak
http://feedproxy.google.com/~r/Collective-evolution/~3/jamiTCHQuKI/?utm_source=feedburner&utm_medium=email
Posted: 15 Apr 2015 04:38 AM PDT
“Ere many generations pass; our machinery will be driven by a power obtainable at any point in the universe.” – Nikola Tesla
A Reactionless AC Synchronous Generator (RLG) has been invented by Paramahamsa Tewari, electrical engineer and former Executive Director of Nuclear Power Corporation of India. His background includes engineering project management for construction of nuclear power stations. The efficiency of models he has built, which have also been independently built and tested, is as high as 250%.
In November 2014, I made one of many visits to the laboratory of Paramahamsa Tewari. I had seen the basis for the RLG design in September of 2010. Mr. Tewari showed me a stiff conductor about a foot long which was allowed to rotate at the center and connected at each end with small gauge wire. A magnetic circuit was placed under the conductor. When a current was allowed to flow through the conductor it rotated, due to a torque induced on the conductor according to Flemings Left Hand Rule and standard theory, verified by experiments at the dawn of the electrical age. With a simple rearrangement of the magnetic circuit, the same current produced no rotation – the torque was cancelled. I later duplicated the setup and experiment on my workbench. It is ingenious and lead to his breakthrough, the invention of a reactionless generator with greatly improved efficiency.
This experiment has lead to the design and testing of generators with efficiencies far above any previous design. The design uses the same types of materials used in current generators, but the magnetic circuit within the machine is configured to cancel back torque while inducing current and producing power. This might be compared to the rearrangement of materials by the Wright Brothers to build a surface with lift that resulted in manned flight in a time when many, including scientists, said it was impossible. Indeed, physicists who cling to an outdated model of the properties and structure of space have declared what has been done by Tewari to be impossible.
During the November testing I witnessed two tests of efficiency on the new model in Tewari’s lab. The second test was several percent better than the first and produced 6.6 KVA with an efficiency of 238%. A second set of stator coils was not connected yet but is expected to increase output to 300%. This is a 3 phase, 248 volt Hz, AC synchronous generator operating at 50 Hz. State of the art, true RMS meters on the input and output that measured KW, KVA, and power factor confirmed the readings of meters we had supplied for tests I observed in April of 2014.
We were able to visit a 130-acre factory site of one of the top electrical machinery manufacturing companies in India. At this site the company manufactures rotating electrical machines, including generators. When the chief electrical engineer first saw the drawings and design of the RLG he knew immediately what it meant for efficiency! Because of their confidence in the design, and the results of the tests on the smaller model, the company has assembled a self-excited machine designed to produce 20 KVA.
When we arrived at the factory a vice president of the company, the factory general manager, and the chief engineer greeted us. We then inspected the new machine and met the engineering design team assigned to this project. They are electrical and mechanical engineers who design and build conventional generators with output as high as 500 KVA. They are very enthusiastic and understand the breakthrough. A second machine rated at 25 KVA is now under construction at this company in India.
kva
I believe, as do the engineers in India, that this is the biggest breakthrough in rotating electrical machine design since Faraday’s invention of the electrical motor in 1832. The elimination of back torque allows all the energy generated to pass through the machine. Power output is determined by the strength of the excitation magnets and the synchronous reactance (resistance at 50/60 Hz) of the stator windings. Current models can be cascaded for higher output. Each machine can produce at least 2.38 times the input and can be configured in a self-running mode. Due to concentration on efficiency and design improvements the machine has not yet been configured in this manner.
During a visit to witness tests in December of 2012, we were guests of the engineering director of a large utility company, and we toured a generation facility which the director pointed out was ready for RLG systems as soon as they are scaled to the required size. In March 2015 we returned to India for licensing discussions. Current plans call for introductory models to be marketed at 10 KVA and 25 KVA. A second company is involved in manufacturing discussions and the Karnataka Power Corporation, which supplies Bangalore, is investigating the use of 200 KVA units in a wind farm application as described in the April 7th edition of Asia Times.
The November 2013 issue of The Atlantic magazine features an article on The 50 Greatest Breakthroughs Since the Wheel. The RLG is more than just a product or a technical innovation. It is a fundamental change in the way that energy can be generated. It overcomes the inherent inefficiencies of AC generators.
Patents have been filed and the RLG is ready to be licensed to companies that manufacture rotating electrical machinery. In fact, discussions with companies on three continents are underway.
We believe that the RLG is a fundamental discovery, not an innovation. Mankind’s first fundamental discovery was harnessing and controlling fire. The second was the wheel. The third was harnessing and controlling electricity. The fourth was harnessing and controlling the atom. The RLG can turn wheels without the use of fire (fossil fuels) or the atom (nuclear plants). It is a 21st century innovation. The first four of these innovations involved an understanding of material elements. The RLG is based on an understanding of the non-material properties of space.
Paramahamsa Tewari’s search for the nature of reality has led him from study of the ancient Vedas of India to the formulation of Space Vortex Theory. It is a new theory unifying the relationship between space, mass, inertia, light, and gravity. Starting with principles described in the Vedic texts, Tewari was able to delineate a mathematical model that explains the words of Tesla when he said:
“All perceptible matter comes from a primary substance, or tenuity beyond conception, filling all space, the akasha or luminiferous ether, which is acted upon by the life giving Prana or creative force, calling into existence, in never ending cycles all things and phenomena.” – Nikola Tesla,“Man’s Greatest Achievement,” 1907
In Tewari’s words:
“The universal matter is created out of prana since prana is aakaash in motion, and aakaash is the primordial superfluid substratum of the universe.”
The concept that efficiencies cannot be greater than 100% is due to an incomplete understanding of the properties of space. The second law of thermodynamics must be modified to account for the fact that space is not empty, as has been taught for the last 150 years. The RLG operates at what has been called “over unity.” Many experienced electrical engineers engaged in the manufacture of AC generators have independently tested the RLG and confirmed the efficiency ratings that I have observed. It’s time for the physicists to get out of the way and modify their theories while the engineers go about the business of design and production.
The theory and mathematical models can be found at:
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Offline cyr
Re: Breaking News: Over-Unity Reactionless Generator Invented In India
« Reply #1 on: April 15, 2015, 07:50:56 pm »
Well, I'm convinced. How can anyone capable of putting that many nonsense terms into a sentence possibly be wrong?
« Reply #2 on: April 15, 2015, 07:54:31 pm »
Bob's your Uncle  , lets   see  what the " waffling  Aussie"    has to say about this article
Offline Rufus
« Reply #3 on: April 15, 2015, 07:57:49 pm »
I think I will call this "loon spam"
The practice of spamming the internet with information to increase the number of search engine hits and give the loon associated with the information more credibility.
Mods - Feel free to delete this new user and the whole thread.
Offline Howardlong
« Reply #4 on: April 15, 2015, 07:58:39 pm »
Pretty brave first two posts. This seems to be two weeks late in posting for such word salad.
« Reply #5 on: April 15, 2015, 08:01:01 pm »
Dave  would say  "aaaahhh  it's utter nonsense " :-DD
Offline pickle9000
« Reply #6 on: April 15, 2015, 08:02:53 pm »
I wonder if there are any hamsters in there?
« Reply #7 on: April 15, 2015, 08:04:47 pm »
Or even  a     flux capacitor creating all that energy
Offline JackP
« Reply #8 on: April 15, 2015, 08:08:26 pm »
I love how he said it was a fundamental discovery, not innovation, and then goes in to say it is a 21st century innovation
Offline codeboy2k
« Reply #9 on: April 15, 2015, 08:17:38 pm »
It sure is shiny.
Offline Tallie
« Reply #10 on: April 15, 2015, 08:51:51 pm »
Seems legit.
Offline free_electron
    • SiliconValleyGarage
« Reply #11 on: April 15, 2015, 10:16:36 pm »
no moving parts ... produces 50 hz ... hmmmm
Offline EEVblog
« Reply #12 on: April 15, 2015, 10:56:25 pm »
You lost me at
Err, no, try measuring it again, properly  :palm:
All the usual free energy BS - you get first hand account of how they witnessed the testing, a "chief electrical engineer" "knew immediately", using "state of the art" test gear, promises of better efficiency with bigger model, comparisons with the wheel, Tesla quotes, many experienced EE's have verified it, patents on the way, all it needs is to go straight into production  :blah:  :blah:  :blah:
There must be a bot generator for these articles, right?
Offline atferrari
  • Country: ar
« Reply #13 on: April 16, 2015, 12:14:00 am »
The Cordlash straps are a nice and original touch.
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #14 on: April 16, 2015, 12:33:12 am »
He posted a picture of it what more do you want?  :wtf:
Offline pickle9000
« Reply #15 on: April 16, 2015, 01:11:22 am »
And in looking up one of terms I found something that is actually interesting.
"NASA says puzzling new space drive can generate thrust without propellant"
http://www.gizmag.com/cannae-reactionless-drive-space-propulsion/33210/
Offline cloudscapes
« Reply #16 on: April 16, 2015, 01:59:23 am »
MOTOR SIDE
Offline all_repair
« Reply #17 on: April 16, 2015, 02:11:40 am »
Please read again.  He was from the management.  THAT cannot be wrong, anything is possible.
Offline Bud
« Reply #18 on: April 16, 2015, 03:11:10 am »
He did
So it was Not 237% or 239% as you might expect.
Offline LabSpokane
« Reply #19 on: April 16, 2015, 05:32:54 am »
Do you really need Dave to confirm the first law of thermodynamics for you?   :-//
Offline aargee
« Reply #20 on: April 16, 2015, 07:38:53 am »
'Over unity'? Yes - I'm over it!
101 uses for a buzz-word generator.
Not easy, not hard, just need to be incentivised.
Offline niflheimer
« Reply #21 on: April 16, 2015, 07:59:21 am »
Would they be reporters if they did ? :))
Offline Circlotron
« Reply #22 on: April 16, 2015, 08:24:26 am »
Like the blower safety straps on a top fuel engine. After all, that thing is just raring to go!
http://www.bmeltd.com/archive/archive_new/Dragster/images/515.06.jpg
Offline Howardlong
« Reply #23 on: April 16, 2015, 09:02:29 am »
Is this not just radiation pressure? The use of sails in space has already been proven, using solar radiation to provide delta v.
Reasonably speaking this is only useful for minor repositioning in the Clarke belt and minor orbital corrections, and course maneuvers for deep space missions. It won't help getting your hardware into space to begin with though, the force is just too small.
Offline Psi
« Reply #24 on: April 16, 2015, 09:02:29 am »
Likelihood that the laws of physics have just been turned upside down
0.000000000000000000000001
Likelihood someone is lying intentionally or otherwise
0.999999999999999999999999
I for one hope it's the first option, but i will put all the money i have on the 2nd.
« Last Edit: April 16, 2015, 09:04:09 am by Psi »
