Author Topic: Broadcom LED displays  (Read 14371 times)
Offline woodchipsTopic starter
« on: April 26, 2018, 07:30:54 pm »
Used the HP/Avago 7 segment LED displays, in particular the HDSP-A103 low current one, for near 20 years.
The latest batch purchased comes from Broadcom, whoever they are.
Problem is that the old HP ones had a nice uniformly illuminated segment, the Broadcom ones have an obvious spot at one end of the segment. It looks really naff.
Photo shows the old displays to the right, the new Broadcom on the left.
Has anyone else experienced this disasterous drop in quality with other Broadcom displays?
I have asked Farnell what goes, no doubt the answer will be to increase the forward current, in a battery powered device, really good idea!
Offline NiHaoMike
    • Facebook Page
Re: Broadcom LED displays
« Reply #1 on: April 27, 2018, 02:37:10 am »
Broadcom is best known around here as the company behind the Raspberry Pi. Or in the past, infamous for buggy Wifi chipsets.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
The following users thanked this post: amyk
Offline amyk
« Reply #2 on: April 27, 2018, 03:16:07 am »
Also infamously secretive with the documentation for their products.
I didn't know they made LED displays but the difference appears to be due to a smaller die (for cost reasons obviously) and insufficient diffusion. You could try adding another diffuser plate on top to compensate.
Offline Mr. Scram
  • Display aficionado
« Reply #3 on: April 27, 2018, 03:17:58 am »
You can't let everyone know how crappy your products actually are.
Offline ebastler
« Reply #4 on: April 29, 2018, 03:39:53 pm »
Broadcom = Avago = Agilent.
Agilent's semiconductor division was spun out in 2005 and named Avago.
Avago acquired Broadcom in 2015, and decided to change its name to Broadcom.
Apparently a process change in whatever Avago foundry affected your LED displays. But it probably can't be blamed on (the former) Broadcom, who to my knowledge did not bring any LED product lines or factories.
Offline amyk
« Reply #5 on: April 29, 2018, 05:02:52 pm »
What? Every product I have with an LED display, except some prototypes I built myself, has a red/green diffuser plate on top. It improves contrast too.
Offline james_s
« Reply #6 on: April 29, 2018, 05:17:40 pm »
Broadcom CPUs are in practically every domestic router and set-top box on the market, they're huge in the embedded world.
I've used Kingbright LED displays in a few projects and have been very pleased with the look.
Offline NiHaoMike
    • Facebook Page
« Reply #7 on: April 29, 2018, 05:48:34 pm »
Qualcomm (a competitor they tried to buy) also has a very large share of the home networking market.
I wouldn't be surprised if Broadcom dominates the budget media player market (that's a big consumer use case for the Raspberry Pi!), but at the high end, Nvidia is leading the way, only surpassed by full on HTPCs.
Offline james_s
« Reply #8 on: April 29, 2018, 06:05:13 pm »
I played with one of those Nvidia media players and was not terribly impressed. It seems to occupy a rather awkward segment, being far more expensive than the small embedded players including the RPi, while being less versatile than a fullblown HTPC without being all that much cheaper.
Offline NiHaoMike
    • Facebook Page
« Reply #9 on: April 29, 2018, 07:51:33 pm »
$150 for a complete device that does pretty decent 4K upscaling is a decent deal. A low end GPU with equivalent capabilities is not very much cheaper, never mind the rest of the PC. Of course, the gamers and videophiles will go right for the full fledged HTPC.
Online Monkeh
« Reply #10 on: April 29, 2018, 08:54:27 pm »
'practically every'. We'll just ignore: Marvell, Mediatek, Qualcomm, Realtek....
Set-top boxes have an even wider range of chipsets.
E: Oh, don't let me forget: Intel, Annapurna, Quantenna..
« Last Edit: April 29, 2018, 08:56:40 pm by Monkeh »
The following users thanked this post: NiHaoMike
Offline james_s
« Reply #11 on: April 29, 2018, 09:03:22 pm »
I don't care about 4k, 1080p video looks just fine to me. If I wanted to upscale it I would just let the TV do the scaling.
Offline rob.manderson
« Reply #12 on: April 29, 2018, 10:19:14 pm »
Jeez, I'm quite happy with 480P on a 55 incher (140cm)!  Must be easily pleased  :-DD
Offline NiHaoMike
    • Facebook Page
« Reply #13 on: April 29, 2018, 10:31:43 pm »
If 1080p is all you need, a Raspberry Pi would be almost the ideal media center for you, unless you're into gaming.
The upscalers that accept HDMI (that includes all TV upscalers except the ones used by smart TV apps running on the TV itself) will never work as well as those done by the media playback device because of the need to keep latency reasonable. Nvidia GPUs actually have two ways to scale - one in the output stage that is very low latency and works well for gaming, and the other is done by code running on the shaders which is used when latency is not important but quality is. The latter is the one mpv uses, while the former is set using nvidia-settings and applies to everything on the screen.
There is a nostalgia factor to it, when the pixellation is part of the experience. Like how Minecraft intentionally uses very low resolution graphics.
« Reply #14 on: April 29, 2018, 10:39:26 pm »
Nah, it's just that I'm old enough to have spent most of my life watching 625 line PAL or Beta tape playback of same.
But I do use a Raspberry PI as my media playback device - lovely little machine!
Offline rdl
« Reply #15 on: April 29, 2018, 10:42:04 pm »
I have plenty of DVDs I ripped that are only 480 vertical resolution (same as the original) and they are more than acceptable when played back on my 42" using VLC. I think I ripped most of them at around 1500 kbps. They probably look better than when originally viewed on a 27" TV with scan lines.
Offline james_s
« Reply #16 on: April 30, 2018, 03:28:47 am »
I've always been quite picky about picture quality, the difference between 480p and 1080p is substantial, the difference between 720p and 1080p is significant enough, but between 1080p and 4k I can barely tell.
Regarding 480i SD content I think it generally looks terrible on a modern flat panel TV but I still have an old 27" Trinitron XBR CRT in the basement and it produces a fantastic picture with SD content. There is no pixelation with analog.
Offline NiHaoMike
    • Facebook Page
« Reply #17 on: April 30, 2018, 03:47:32 am »
TastyPC recently came back in 4K and the difference between actual 4K and 1080p upscaled to 4K was noticeable. An easy way to tell is to look at fine details like her hair - remember that the details 1080p was not able to capture cannot be put back by upscaling. (It's amazing how she manages to look flawless in 4K...)
Offline james_s
« Reply #18 on: April 30, 2018, 06:20:46 am »
How much real 4k content is there though? Most of the movies I own are still from DVDs, more recently I've been buying bluray versions but I'm not going to re-buy all the movies I already own. I have not yet seen an actual 4k movie, only some demo videos.
Offline NiHaoMike
    • Facebook Page
« Reply #19 on: April 30, 2018, 07:04:19 am »
4K is only going to increase in popularity as the cameras become cheaper. Remember the early days of 1080p?
The way TastyPC suddenly came back in 4K got me by surprise. The question of when my GPU will get to run the fine tuned upscaler again (i.e. get new content that can actually make good use of it) is still open.
Offline ruffy91
« Reply #20 on: April 30, 2018, 08:28:27 am »
I regularly watch 4k HDR movies on our 65" OLED TV. (to be fair only ~50Mbit/s, Netflix). You wont believe me how good it actually looks. You can see the details in the shadows AND in the bright parts of the picture at the same time.
To be fair though 1080p HDR looks good too, but the textures are not as sharp as with 4k video material.
Offline james_s
« Reply #21 on: April 30, 2018, 05:06:19 pm »
Well I'm sure some day I'll end up with a 4k TV but for now the 65" 1080p set I got for free and fixed has been working great. I'm not sure 4k movies are going to be worth the space on my Plex server but maybe hard drives will keep getting cheaper. From watching demos on 4k TVs I can make out the difference if I really look closely but it's incremental at best. Going from SD to 1080p was a very large improvement. I wonder what they'll try to come up with next? Hard to imagine much improvement beyond 4k.
Offline dmills
« Reply #22 on: April 30, 2018, 05:29:45 pm »
The consensus in the broadcast business is that HDR is a real improvement, 4k is great for monitors (where you are sitting close and the pixel scale works with the circles of confusion), but mostly a waste on a telly unless completely unreasonably sized.
HDR, especially HDR that actually means it, lots of things sold as HDR do not manage the required brightness or required graduation in the black end of the scale, is a very clear improvement, 4k less so for telly.
HDR also has the virtue that it can reasonably be compressed into a SDR image, so one camera and production chain can do both with some fiddling, the chain does not even need to be 4k capable, bog standard 3G-SDI will get her done, as 4k is basically a different gamma curve so new monitors and a new grading monitor, but all the switchers and routers can stay more or less unchanged.
Regards, Dan.
Offline Mr. Scram
« Reply #23 on: April 30, 2018, 07:28:39 pm »
Upscaling is upscaling. Unless you unleash some neural network magic and actually fill in the detail, it's mostly just smoke and mirrors to fool yourself.
« Reply #24 on: April 30, 2018, 09:14:18 pm »
I noticed this as well. I bought one (different series) to replace a display in a clock my father built years ago.
Intensity was focused on one side of the segment. Plus until I replaced it I didn’t see how orange the old displays had got. Ended up just buying 4 Kingbright displays. Much nicer and cost less than the single bloody Broadcom one.
