Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Building DMM leads
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Building DMM leads (Read 3597 times)
WhiteFireDragon
Regular Contributor
Building DMM leads
on:
November 17, 2012, 07:57:46 am »
I'd like to build leads for my multimeter. Yeah, I can just buy them, but I like building stuff and I also want some customized tips. Here are the parts I came up with so far:
Alligator clips:
toothless clip
(for LED wire),
standard clip
(for general purposes)
banana plugs:
shrouded
(for DMM),
non-shrouded
(for alligator clip side)
probes:
test probes
(plugs into banana plugs)
wires: ??
I'm assuming all banana plugs are 4mm sizes? Please check if the banana plugs I choose are correct, because I'm not sure if I can solder a wire onto those. And I need help on which wire/cable to get. I would like something really flexible, so I'm assuming silicone insulated wires? Also, copper clips are better at conduction, but will corrode faster than steel, correct? Thanks in advance
Logged
T4P
Super Contributor
Country:
Re: Building DMM leads
Reply #1 on:
November 17, 2012, 08:05:56 am »
Silicone AWG16/18 wires
And look for another type of non-shrouded jacks, the pomona ones are terrible quality that comes from china (Don't assume!)
But in my knowledge "wireless" test leads usually accept shrouded ones
Logged
WhiteFireDragon
Regular Contributor
Reply #2 on:
November 17, 2012, 09:40:24 am »
Ok I'm going to go with these
16awg silicone
wires. I'm hoping total diameter is less than 4.5mm because the shrouded banana plug can't accept wires any bigger according to the
data sheet
. I'm also going to go with
THESE
4mm banana plugs because they look less cheap, and require soldering of the wire for attachment. What are the standard wire sizes for multimeter leads, like the ones Fluke uses? I'm looking for the biggest possible wire that can fit to minimize the resistance.
Logged
T4P
Super Contributor
Country:
Reply #3 on:
November 17, 2012, 09:45:47 am »
No idea but the probes i have are mostly 95cm-120cm or 1.2m
Logged
WhiteFireDragon
Regular Contributor
Reply #4 on:
November 17, 2012, 10:07:30 am »
Ah I meant wire thickness, not length. The leads from my amprobe has wires that are 3.5mm thick, so I'm hoping 16awg wires won't be more than 4.5mm thick, otherwise it probably won't work with a lot of the parts I'm ordering.
Logged
notsob
Frequent Contributor
Country:
Reply #5 on:
November 17, 2012, 10:37:47 am »
Read this thread for source of silicon wire, bananas and general technique
https://www.eevblog.com/forum/product-reviews-photos-and-discussion/high-quality-banana-plugs-alligator-clips-ect/msg146653/#msg146653
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Building DMM leads
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
