But here's the thing: The cost to maintain electricity to the meter is paid for by energy consumed through the meter. If PG&E isn't selling kWh, they can't afford to maintain the system at the residential level.
Let them deal with the industrial customers. Individual homes should be solar , no selling electricity into the grid, and a connection for nighttime , or off-season use only. That would lighten the load on the grid.
Stick a 20KWh pack in the garage.
To be effective, an array probably needs to be around 8 kW in the Sacramento area. We had that size and it covered all of our kWh for the year. All we paid PG&E was the $5/month meter charge. We were paying $0.15/kWh to the solar company instead of $0.35/kWh to PG&E
perfect !
One of the rules: You can't be a 'net generator'. PG&E doesn't want to buy back solar energy.
There's no need. Whatever excess you produce : dump it in a pack. And if you combine roof space for electric and warm water ... two birds with one stone.
Actually i wonder how come nobody makes cooled solar panels. Basically run a non conductive cooling fluid on the back of the panels pumped through a heat exchanger into storage for warm water.
Cooling the cells gives ore efficiency and you get free warm water ... Even if the cooling shuts down , or there is enough warm water : it won;t damage the cells as they are already capable of handling the full heat.
Battery systems are going to be a maintenance nightmare.
Not really. And it doesn't have to be pure battery . bloomboxes look interesting. Anyway, for night time use you would still pull additional (but reduced) power form the grid.
I'm not sure that battery systems can provide enough kW to cook Thanksgiving dinner. One of the things about solar is that it is useful for kWh but not so much for kW. I doubt I can afford a battery system large enough to run a 5 ton HVAC unit along with the usual kitchen appliances along with another couple of horsepower for a garbage disposal and the all important well pump (also 2 HP, I believe). There's a reason the house has a 200A service.
52KW inverter enough for you ? Size of two shoe boxes. That easily 200 amps at 240 volts.
I have a 5 ton AC and electric range. 120 amp service. no problems. 200 amps is excessive. You only need it for night. Nights are cooler, less AC consumption. You really only need power for fridge/freezer ,interior lighting.
I have a very efficient AC system ( variable speed scroll compressor with variable speed furnace/exchange ). It maintains the house at fixed temp throughout the year. i cut my summer electricity bill in half by switching to such a system. no more bang-bang approach to cooling. OK, the system cost money i will probably only start recuperating after 10 or more years, but it can be done. It lightens the load ont he battery pack.
You need to shift and adapt new technologies to work on a pack based system, but the machinery does exist.
