I have a problem with many of my older CD-R's and I'm wondering if anyone has noticed the same issue.
Most of them are getting CRC errors (cyclic redundancy check) *only* on the files that are near the outer-most edge of the disc (the last files written to the disc). The files were burned in alphabetical order, as a single session and then disc closed.... Now, almost 5 years later, when I try to copy them back to the hard-drive, it can handle almost everything but the last 40-50 MB.
I wrote the CD-R's as a single session and closed the discs. Most are about 3-5 years old. Many are supposedly 700 MB, so I filled them. I don't remember what I used to burn them, it may have either been Nero or Power2Go which came with my ASUS laptop. And I am pretty sure that I had them verify the disc after burn.
So a few things may be happening here (from my limited knowledge of optical drives):
1) The drive I am reading them with is somehow "running out of calibration" sync as it nears the outer-most tracks on the burned CD-R. I've tried other drives as well but not had any better luck. The drive I'm using is oriented vertically, the one I burned in was horizontally-mounted.
2) The media I used is crap. However, I used Staples brand, Mitsumi, Maxell, TDK and Philips. Both rated at many times burn speed and 700 MB. And if it was crap, why did it verify properly? I haven't noticed any trends yet, but I'll keep looking.
3) The burner software I used was crap and lied about verification or was only able to verify on the drive on which it was burned (see #4).
4) The drive I originally wrote the CD-R on had some quirk which allowed it to read/write out near the edge of the disk but every other drive doesn't follow the same quirk so it has problems.
5) The media is degrading from the edge of the disc towards the inside, or the centrifugal force or simply the increased radius is causing the most "wobble" out near the edge of the disc leading to problems reading the outer-most 50 MB or so.
So in summary, I have about 100+ CD-R's all burned around the same time, various brands, all on the same computer and as a single session closed CD-R in alphabetical order file listings. I am able to copy about 50% of the CD-R's no problem.
The other 50% always seem to copy almost to the end of the CD-R.... but the last 50 MB or so (it varies) on different brand CD-R's give me CRC errors on the files. So I have to use IsoBuster to try to copy the files... There are always errors, which I need to IGNORE to continue copying.
One other thing that might be important. The files are typically 8-10 large MP3 mix files... each is about 60-100 MB in size, usually 1-2 hours worth of music. So when there is an issue with the CD-R, it can copy usually the first bunch of files, and then the last MP3 file (usually 60-80 MB in size) has the error about half way through it.
I choose to IGNORE the error in IsoBuster and it copies the file, but when I listen to it there are glitches throughout most of the MP3 beyond that point. I can still listen to it, but there are obviously problems.
I am not too troubled by this because it is just MP3 music, so if I lose some I don't really care. But I just want to know for my own sake and the future of my more important files what is happening here. Any thoughts?
EDIT:
One other thing... Old fingerprint smudges near the edge of the CD, maybe the oil had deteriorated or hardened on the surface or something.
