Author Topic: Chinese solder wire brands?  (Read 23542 times)
Offline kalelTopic starter
Re: Chinese solder wire brands?
« Reply #25 on: December 09, 2017, 04:00:48 am »
Add five kopecks: review (not my) of Chinese "blue Kaina" soldier and comparsion with "shit cheap noname solder from Aliexpress" and "tape of unknown solder". In Russian, but photos are clear without translation.
P.S. Warning! Heavy animated GIFs.
It seems the "KAINA" did pretty good in this test?
Offline Canis Dirus Leidy
  • Country: ru
« Reply #26 on: December 10, 2017, 07:44:26 pm »
Yes (at least this particular spool). Author mentioned that there is also "orange KAINA", but, according to opinions, it is worse.
P.S. Review of another cheap Chinese solder (JINHU). TL;DR: For just $1.66, you get whole 15 gram of unknown alloy wire (it began to melt only at 273 °C, despite 63/37 claims, plus dull solder joints).
Offline nanofrog
« Reply #27 on: December 10, 2017, 08:29:33 pm »
The alloys may be flipped @ 63% Pb + 37% Sn. Cheaper to make as lead is less expensive than tin, and would generate the indicated results (higher melting temp & dull joints). FWIW, this seems to have happened with 60/40 in another thread on Chinese solder brands.
Offline IanMacdonald
    • IWR Consultancy
« Reply #28 on: December 11, 2017, 07:36:00 pm »
Not Chinese, but any opinions on Billiton solder? Seem to recall using it years ago but can't remember what it was like.
« Reply #29 on: December 24, 2017, 05:31:47 pm »
This one seems to have decent comments on eBay (although few and not detailed):
https://www.ebay.com/itm/Tin-Le-Solder-Core-Flux-Soldering-Welding-Wire-Spool-Reel-0-8mm-63-37-N3/121930059734
Great deal!
Great deal, great price. Solder works well...no problems
Good quality
It is enough for the iron jobwith its quality.
Of course, I really doubt the quality just based on the price.
Online Monkeh
« Reply #30 on: December 24, 2017, 05:33:57 pm »
I'm sure they're both legit and from people who know how solder is supposed to flow.
The following users thanked this post: Bassman59
« Reply #31 on: December 24, 2017, 05:51:22 pm »
With some of these you get many less grams than promised, so much that the price might in some cases equal or exceed some branded wire (at say 100g).
In those cases, it's not as cheap as it seems, while still not being good quality.
Offline tooki
« Reply #32 on: December 24, 2017, 10:59:20 pm »
I've yet to try 63/37 so I have no idea how it feels versus some (normal brand) 60/40. This is way out of topic, but is it really easier to use for beginners?
It’s a subtle difference between them, really. But the point is that 63/37 is eutectic, meaning it’s an alloy with a single melting point, as opposed to a non-eutectic alloy whose melting (and thus resolidifying) happens through a temperature range. (63/37 melts at 183C, 60/40 melts at 183-188 or 183-190, depending on who you ask.) This range is called the “plastic phase”, meaning malleable. So it means that when cooling off, 60/40 solder has a split second where it’s sort of mushy and can be moved a bit before it hardens. This makes it easier for beginners. But because movement during cooling causes irregularities in the crystal structure of the cooled metal, it produces a weaker “disturbed joint”, which is actually undesirable. 63/37 hardens quicker, so the time window for producing a disturbed joint are lower.
I prefer 63/37 myself. But as I said, it’s a very subtle difference, so if one or the other is easier to procure, then that’s fine, and either will produce excellent results provided your technique is halfway decent.
The following users thanked this post: kalel
Offline Kilo Tango
« Reply #33 on: December 24, 2017, 11:16:52 pm »
60/40 has advantages when trying to "fillet" a joint. SMD components are tiny and once the solder sets they stay put, however some components take a mechanical load and need support. The plastic phase of 60/40 lets you fillet the joint so it is a lot mechanically stronger.
Here is a picture of the power connector from a relatively modern TV, a 29" Cello. As you can see the soldered joint has failed; the lead free solder is like water, and when it sets it is very thin and offers not a lot of mechanical support. I repaired it using 60/40 and got a nice filleted joint. Its been working for the last 2 years without problem. I sometimes turn down the iron temperature to make it more plastic to fill in loose joints.
Ken
Offline tooki
« Reply #34 on: December 24, 2017, 11:35:59 pm »
I don’t mean to be rude, but this is literally nonsense. As in, it literally doesn’t even make sense.
What’s called the “fillet” in soldering is simply the shape of the meniscus caused by the surface tension of the molten solder. It applies equally to both leaded and lead-free solder — they produce identical fillets. If you’re getting radically different results when soldering with one vs the other, then something is radically wrong with your technique.
I don’t even know what you mean by “filleting” the joint — the fillet forms automatically from the correct application of solder — too little and you have a dinky, weak joint; too much and you have a convex glob instead of a nice concave fillet. (The component lead and PCB pad geometries of course are also defining factors in the shape and size of the fillet.)
Solder is NOT supposed to provide primary mechanical support. Of course, cheap stuff often relies on the strength of solder joints alone, but that’s bad design. (As in the picture you posted.) Especially with lead-free, which is very brittle, proper mechanical support is critical.
Like water? What the heck are you talking about? As I said, the size of the joint depends on how much solder was applied.
Leaded solder is more flexible than lead-free, so it can handle flexing better without failing.
Wait a sec — you mean you’re deliberately using a far-too-low temperature so you can glom on mushy-state half-melted solder to a joint?!?  :o
I can’t even wrap my head around how bad that is as a technique. Solder joint strength relies on the fully-molten solder actually slightly dissolving the base metal of the component leads and PCB pads, so they fuse into a strong joint.
The following users thanked this post: Bassman59, kalel, lisafig
Online David Hess
  • DavidH
« Reply #35 on: December 25, 2017, 03:23:42 am »
I have never been able to discern a working difference between eutectic Sn63Pb37 and non-eutectic Sn60Pb40 when filleting a seam.  Sn60Pb40 is slightly less expensive and works practically as well but I still prefer Sn63Pb37.
Online GigaJoe
« Reply #36 on: August 02, 2018, 03:26:34 am »
got blue kaina, and red kaina -
blue melt below 200C,  red 230+ C (my solder +200C are min )
but but .... seems (again I not sure) a flux not so aggressive as 245 kester
but in overall if no alternatives blue kaina are good to go ....
Offline ali_asadzadeh
« Reply #37 on: April 17, 2019, 07:34:09 am »
anyone has experience with JF brand from china? I need BI57SN42AG1 ones, and they seem to have them, any experience with them?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline rrinker
« Reply #38 on: April 18, 2019, 03:39:35 pm »
 Julian Ilett seems to be on a bit of a solder testing tangent lately, he's been ordering different Chinese brands and seeing how well they work (2 different ones so far).
Offline tooki
« Reply #39 on: April 18, 2019, 05:36:59 pm »
With reputable-brand solder being so cheap, it escapes my why anyone would waste their time with el-cheapo Chinese solder...
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #40 on: April 19, 2019, 01:47:19 am »
Which ones? I checked amazon and the only non-Chinese brands I see are Kester and MG chemicals, which are over 3 times as expensive per gram compared to what you can get decent Japanese branded solder for here. Same thing on "reputable distributors". It's beyond me why none of the distributors (or even amazon) sell any of the Japanese brands, but only the overpriced brands. Really the thread title should be changed to "how to obtain Japanese branded solder outside of China"...
Email: OwOwOwOwO123@outlook.com
Offline tooki
« Reply #41 on: April 19, 2019, 10:26:58 am »
Being unfamiliar with Japanese solder, I can't comment on it.
But my point is that name-brand solder isn't expensive in absolute terms. Even at $65-120 for a pound 454g or 500g spool of SAC305 (from Digi-Key, for example), the amount of solder used in a project is so small that the absolute cost is negligible. So I just don't see a reason to risk the cost of ruining a project (or even just of wasting time) by using Chinese solder of unknown quality. There's no question that what one is paying for in a premium-quality solder is for confidence. Kester, Multicore, and MG will not let you down.
Offline Corner
« Reply #42 on: September 11, 2020, 04:29:57 pm »
Late to the party.
I've been using Mechanic brand solder for a while now. It produces comparable results to Multicore 309 60/40 which was what I used before I switched to Mechanic. It's been consistently good. This is the only good Chinese solder brand I know other than Pro'sKit. Tried too many shitty Chinese solder I don't wanna go waste more of my money and time.
So if you want good quality (flows well, shiny joint etc) solder from China, Mechanic and Pro'sKit are probably the only brands you wanna look at. I'm happy to be corrected though if you guys find other good ones.
« Last Edit: September 16, 2020, 06:33:38 am by Corner »
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #43 on: September 11, 2020, 09:35:17 pm »
This Kaina blue solder is really good has a low melting point 200deg. it flows really well hardens to a nice shine . excellent for de soldering smd's . Low smoke , very clean. and I found it very useful when soldering terminals on batteries and hard to get to places . flows quick and easy .
Makes good contact on all surface . also nice for bridging and tinning .
 I am very happy with this solder I can say its one of the best solder about .
 :popcorn:
its 60/40 and uses CF10 flux .  :-+
« Last Edit: September 11, 2020, 09:37:07 pm by Labrat101 »
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
Offline jonsig
  • Country: is
« Reply #44 on: December 19, 2021, 01:19:44 pm »
sorry for reviving old thread.
But i´m interested if there are other good chineese solder wire brands.
I´ve used this sky-blue / kaina solder. And it´s very easy to work with. It´s low residue flux that does not stain the tip of my metcal, and it does not give off strong odor like kester 245 . thou i´m not 100% sure about the consistency of the alloy composition.
Also have only found one flux brand acceptable from aliexpress, Xeredex it´s not full of vaseline . And its not so far-off from my most commonly used fluxes Amtech NC-559-V2 and Topnik Zel in performance.
Offline Labrat101
  • Regular
« Reply #45 on: December 19, 2021, 02:35:11 pm »
I recently bought some of that Amtech 559 . The dealer said it was original. But it is fake it's made by Jiyang solder company which do infact make good flux .Amtech flux is not made in any other country only in the USA.
But the fake works really well the one I got does.  Some Amtech fakes are horrible.
Kingbo flux is fair bit greasy but does work ok.
For solder I now only use Kaina cf10  2% flux 63/37 .
If you have endless money Multicore from the UK is very high quality.  But you will have to pay stupid shipping costs.
Offline jonsig
  • Country: is
« Reply #46 on: December 21, 2021, 09:11:16 pm »
Well i recently bought 1.5kg´s of kester in various thickness / composition. Had i known this kaina brand beforehand then i wouldn't bought anything from kester.
This kaina stuff gives of no smell, because it´s probably super toxic.  It does not stain my tips which is extreme problem for me when using high temp tips on Metcal.  ^-^ and does not mess the pcb when sholdering.
« Last Edit: December 21, 2021, 09:13:13 pm by jonsig »
