What make/model is it? If there are any references to patent numbers, you could look those up and the patents will usually have quite detailed diagrams of the mechanism. It looks like a typical spool-valve to me, you can try turning the water on with the valve out to flush out any debris. Backflushing from the shower end might be more effective.
