Author Topic: Computer for Apollo  (Read 10795 times)
Offline atferrariTopic starter
  • Country: ar
Computer for Apollo
« on: February 22, 2015, 12:23:05 pm »
I run across this video
http://youtu.be/YIBhPsyYCiM
I got surprised to learn that still there they used a sextant to measure angles between Earth and starts but looking at the date, no surprise.
Incredible the hard work they did to solve one by one all the steps to build such a computer. Wiring the memories...!  :palm:
Starting at around minute 6, the panel of the computer is shown. There are two words "verb" and "noun". Does anyone could tell what they actually mean in this context?
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
Online John Coloccia
Re: Computer for Apollo
« Reply #1 on: February 22, 2015, 12:46:24 pm »
The "verb" is the command, and the "noun" is a parameter for the command.  I don't know much about the Apollo computer, but just as a made up example, let's say you want to recall the last recorded position.  Perhaps you might enter a command like this:
verb: Display
noun: Last Position
Maybe you want to see time of flight.
verb: Display
noun: time of flight
Again, I'm just making it up, but that's basically how it used to work.
Offline Mechanical Menace
« Reply #2 on: February 22, 2015, 12:59:58 pm »
The sextant was hardly your "olde fashioned" affair, even if they do still have them as backups nowadays.
Just looking at the pic I'd love to get my hands on a modern equivalent.
« Last Edit: February 22, 2015, 01:01:45 pm by Mechanical Menace »
Second sexiest ugly bloke on the forum.
"Don't believe every quote you read on the internet, because I totally didn't say that."
~Albert Einstein
  • Country: ar
« Reply #3 on: February 22, 2015, 01:31:46 pm »
By that time I used them every day on board and I did so, long after the satellites were installed in our vessels. My last voyage using it intensively was from Philippines all the way down to Argentina doing the morning / evening calculations with stars.
Since practice makes for perfection I started to compete with myself to see how many fixes (of different starts or even planets) I could take in one period until the horizon did not allow for more. My record, 14.
The one in the picture, is it for aeronautical use? I do not recognize much in it. Is it complete? Any link?
Agustín Tomás
  • Country: ar
« Reply #4 on: February 22, 2015, 01:34:55 pm »
verb: Display
noun: Last Position
verb: Display
Gracias for replying. It makes sense now.  :-+
Agustín Tomás
« Reply #5 on: February 22, 2015, 01:47:51 pm »
That's the sextant used for the Apollo missions, through the sound of things to compensate for errors in the inertial guidance system.
http://www.ion.org/museum/item_view.cfm?cid=6&scid=5&iid=293
~Albert Einstein
  • Country: ar
« Reply #6 on: February 22, 2015, 01:56:43 pm »
Interesting site.
Gracias MM  :-+
Agustín Tomás
Offline amyk
« Reply #7 on: February 22, 2015, 04:05:53 pm »
Schematics: http://klabs.org/history/ech/agc_schematics/
Imagine designing a whole computer with nothing but 3-input NOR gates...
« Reply #8 on: February 22, 2015, 04:35:03 pm »
Interesting site, thanks for sharing.
I am wondering why they went for 3 input NOR gates instead of 2 input NOR or NAND gates? Will have to get reading.
~Albert Einstein
« Reply #9 on: February 22, 2015, 04:58:33 pm »
They probably wanted more logic elements, but a 3 input gate is useful and can be used to make any other gate easily. As well you only need 2 to make a RS flip flop, with the extra gate providing a nice clear function for it. As that was likely the most reliable IC that you could make at the time with 3 transistors on it, and used identical value resistors throughout with at least good tolerance for production spread this was probably a big deciding factor.
« Reply #10 on: February 22, 2015, 06:10:15 pm »
Didn't think of that one, less wasted transistors than hooking up loads of 2 input gates...
~Albert Einstein
Offline albert22
« Reply #11 on: February 22, 2015, 06:26:55 pm »
Thanks for the very interesting links posted. Definitely the choice of only one IC type was made for reliability.
A very important purpose for the sextant was to align the inertial platform to several coordinate systems. This allowed the computer to point the apollo and fire the rockets to the exact trajectory. The computer calculated the position by using  stars and relevant point in the earth. But it was more accurately determined from the earth by several tracking stations and by measuring the delay and phase of the radio signals travelling from earth to the spacecraft and back to earth. I read that in this way the error was just a couple of meters when they were near the moon.
« Reply #12 on: February 22, 2015, 06:39:35 pm »
370,000,000 metersish and only out by a couple when they got there? Technology has come a long way since the 60's and they managed that and yet we can't even get out of LEO nowadays :wtf:
~Albert Einstein
  • Country: ar
« Reply #13 on: February 24, 2015, 03:52:41 pm »
Digging deeper and wider I came to more info here
http://timeandnavigation.si.edu/artifacts/search?field_topic_tid=3
Impressive.
Agustín Tomás
Offline free_electron
    • SiliconValleyGarage
« Reply #14 on: February 24, 2015, 03:55:56 pm »
More TTL , less VHDL !
Offline AdShea
« Reply #15 on: February 24, 2015, 07:46:53 pm »
RTL, not TTL. They only used pull down NPNs and resistors there (4 R + 3PNP for one gate).
Offline GK
« Reply #16 on: February 25, 2015, 03:03:10 am »
Or NAND gates which are logically equivalent depending on interpreting the IO as either positive or negative logic.
Not a particularly onerous task in either case......
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
