Excerpts from other posts of mine.
I get the bottled liquid instead of the spray. If I need to spray it I put a drop or two in a fine solder paste dispensing needle and put it on my paste dispenser and give it a 70psi blast. With that you can get into places the spray cans cant touch.
I don't have a problem with spray cans. I just like the versatility and cost effectiveness of the bottles or tubes.
You never run out of propellant pressure with my method and you can swab every last drop out of the bottle. I keep a
micro brush applicator with each bottle for non spray application. I have more control with the hypodermic/paste dispenser method as to the amount and where it goes. a carefully located drilled source (and drain if needed) micro holes in a switch or pot can allow cleaning and lube without disassembly. You can put as much IPA or your favorite cleaning solvent into a glue dispenser syringe as you feel appropriate and inject it under pressure. Then take the piston out of the syringe and blow it out with just the air. Then blast the conditioner or lube in.
This is what I did to my de-oxit bottles. I flattened the bottoms of the bottles with a harbor freight diamond block to get a roughened flat surface that super glue would adhere well to. Then super glued it to a suitable block of steel so tipping them over is way less likely and I only need one hand to open or close them.
