A while back I picked up a used BK Precision 1672 (dual 0-33v, 0-3a PSU, with a third fixed 5v). Sadly, the clown I purchased it from didn't bother to put the top piece of styrofoam in the box and the thing bounced around like a pin ball. And in the process sheered off all four pots, including the two push-pull pots on the master side (a pot with a built-in DPDT switch).
A friend and I did some temporary repairs (putting the push-pull pots back together, stringing wire from the pcb to the broken terminals of the pots) to verify that I wouldn't be pissing money away if I replaced the broken parts. The PSU worked great with the temporary repairs. After I replaced the broken pots with new parts though, the thing only worked for < 30 seconds. I turned the voltage dial through its range, and at almost the top, it crapped out (the lights are on, but the output voltage is 0v)
I verified I replaced the parts with the same values, the pots are 10k. I've checked the fuses on both the master and slave board and everything checks out. The fixed 5v works and outputs 5v as it should.
If I disconnect the communications wires between the primary and slave boards, everything works as it should. With them connected, I get 0v on both the primary and secondary.
UpdateI think its the push-pull pots I got that caused the issue. While fiddling around with it, I slowly pushed in the put and noticed that the display flickered. When I slowly pulled it out, I heard a pop, and saw some magic smoke. Upon investigation, the back of transistor Q102 (C1815) is completely blown off. I pulled the master side PCB off and put the meter across the opposite poles of the switch and slowly pushed/pulled and there is definitely a spot there where the switch on the replacement push-pull pot bridges both sides together
So, now that I think that I know what the issue is, does anyone know where I can get a good 10k push-pull pot from? The ones I ordered came from fleaBay because that was the only source I could find at the time. The ones I need are pins, not lugs.
Thanks,
Dan
