Author Topic: Goodbye Windows, Hello Linux [advice needed for a Linux workstation at home]  (Read 29536 times)
Offline thermistor-guy
Re: Ditching Windows at home [Linux advice needed]
« Reply #150 on: January 22, 2019, 01:53:20 am »
... While most people would laugh at this old hardware, it is now saved from landfill and this family can enjoy new life out of this computer which they thought was otherwise useless.
I keep my family's PCs running for as long as possible, by doing simple repairs and cheap h/w upgrades, often using spares from my junk box; then wiping Windows and installing Linux. My everyday home admin PC is a 2007 Dell laptop running a Linux Mint LTS distro. It can't run games, but it can run movies. Older h/w can have a high build quality, well worth preserving. In a jam, when your main machines are down, e.g. because Windows has upchucked over your disk, you have a work-around.
One of our Win7 PCs crashed the other day and wouldn't boot. Windows stalled for hours in a repair attempt. So I booted a Linux Mint live CD, and used GParted to do some partition repairs on one of the drives. The system booted and tested fine after that. My kids saw this; they don't want to use Linux, because their friends don't, but they now think Linux is pretty cool. <Sigh> slowly, slowly ...
Offline RoGeorgeTopic starter
« Reply #151 on: January 23, 2019, 02:59:38 pm »
Thank you all for sharing your thoughts.  So far it was very helpful for me.
Now, I'm in the process of freeing up the SSD in order to make room for a clean install.  Very time consuming this sorting out of what to keep and what to delete.  Also, keep moving chunks of folders from the SSD to all the other storage places (NAS, USB sticks, external HDDs, internal HDDs, cloud storage, even SD cards) almost made me completely loose track of what I copied and where.
Being the kind of data hoarder I am, it all ended up buying a 8TB disk, and calling it a delayed Santa and not hoarding.  ::)
Questions
- Inside the PC's case, there is a 512GB SSD.  I will ask about this one later.
- The 8TB HDD will most probably stay outside the PC's case (the motherboard has an external SATA connector, with power).
1. Already decided to use GPT, and don't bother with MBR any more.  How to partition an 8TB HDD?  A single partition, or many?  Or just made one reasonable big partition for now, and let the rest for future partitions or resizings?
2. What file system to use?
3. I am planning to drop NTFS completely for the 8TB disk, yet most of the old data that will populate it is coming from NTFS partitions.  On Windows, there was only one user, so I am not concerned with preserving the Windows access rights.  Is there any good reason to still keep using NTFS for the new 8TB?
Later edit:
I would like to preserve the file date, thought, at least the creation date.
« Last Edit: January 23, 2019, 03:41:54 pm by RoGeorge »
Offline stj
« Reply #152 on: January 23, 2019, 03:31:15 pm »
long term computer users learn to keep stuff they want/need in specific named folders.
it makes things a hell of a lot faster for backups or upgrades.
of course Linux helps by having a "home" root-folder.
unlike winshit that scatters everybody's stuff all over the damned place.
my documents? my files? everybody's files????
what satanist came up with that storage plan???
Offline radar_macgyver
« Reply #153 on: January 23, 2019, 03:43:05 pm »
Would suggest not doing this. Over time, I found eSATA connectors' latches get flaky and cause attached disks to generate ATA errors. I prefer to have my drives internally mounted and if I care about the data at all, with a 2-disk mirror (using mdraid or btrfs).
No partitions necessary. This artificially imposes limits on what you can do, and has no benefit on modern filesystems. When using btrfs, you can instead use subvolumes with quotas so that, for example, you won't end up with a root filesystem with no space left.
btrfs would be my pick. It has its flaws, for example it has bugs in the raid5 code but works very well for a single disk or a mirror. One of the better aspects is how you can 'attach' a mirror to an existing single disk, and detach it later if needed. Another really cool feature is copy-on-write, which lets you snapshot ('freeze') the filesystem while making backups.
I use this to periodically back up my btrfs filesystems to a network drive. Once the initial copy is finished, you only send the changes which can be quite fast. I have a cron job set up to do the incremental backup once an hour. I also maintain snapshots the last 48 backups (on the remote disk) in case I screwed something up and want an older version of a file (similar to Apple's Time Machine).
Nope. NTFS drivers in Linux had to be reverse-engineered, unlike native ext4, btrfs etc. You also lose the ability to store file permissions.
« Last Edit: January 23, 2019, 03:47:33 pm by radar_macgyver »
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
« Reply #154 on: January 23, 2019, 03:55:00 pm »
At least two:
a) OS
b) /home (It allows to update your linux version or distro keeping your personal data files out of trouble)
Some additional:
c) /virtualbox for VMs
d) Swap. I still like a swap partition instead of a swap file.
e) FAT32 for backups
Ext4 should meet your needs
Later edit:
If there's only one user, it seems there's no reason to keep NTFS. I would make some disk image for your old windows system and I would keep it in a FAT32 Partition.
« Last Edit: January 23, 2019, 04:00:24 pm by HoracioDos »
« Reply #155 on: January 23, 2019, 04:08:58 pm »
I was not aware about the btrfs capabilities.  I thought only ZFS can easily to snapshots and thus have "time back" features.  Will read about btrfs.  Thank you.
About the mirroring, that will come later.  I couldn't afford another 8TB for the moment.  The one I bought is pro-sumer/small-business grade, so there is a big chance it won't let me down.
Until then, I will just avoid storing on it any valuable data, personal photos and projects.  For that kind of things I have a RAID5 NAS, very slow (about 10MB/s at most), but very reliable.  For now, the NAS is filled with lots of junk data that will be moved to the 8TB, and from now on, I'll keep the NAS only for personal data.
« Reply #156 on: January 23, 2019, 04:14:11 pm »
@HoracioDos
The 8TB is for storage only.  The OS will stay on a SSD.
I won't use Windows in the future.  This is for sure.  Even if it would to temporarily need a Windows machine, most probably it will be a VM, or a temporary install on another old external drive.
Offline tggzzz
« Reply #157 on: January 23, 2019, 04:30:32 pm »
In the most popular Unix of the 1980s, Microsoft's(!) Xenix, the user foo's home directory was /users/foo.
I believe with Win10 Microsoft has gone full circle and, via a tortuous route, returned to putting much (but far from all) of a user's stuff in /users/foo.
I guess the Windows registry is still the horror story containing whatever anybody wants to put in it this year.
Offline HoracioDos
  • Country: ar
« Reply #158 on: January 23, 2019, 04:31:36 pm »
@HoracioDos
Upss I'm sorry I missed that! Do you already have a partition for personal data on the SSD?
Offline rdl
« Reply #159 on: January 23, 2019, 06:08:07 pm »
I got sick and tired of NTFS years ago. More trouble than it's worth. Ran into far too many instances where I couldn't do something because of convoluted permissions. Now use it only on a small boot drive for the OS only and keep everything else on other drives with FAT 32 or XF 64 or on the NAS with ZFS
Offline nctnico
« Reply #160 on: January 23, 2019, 06:55:23 pm »
Don't setup a swap partition. It will be too slow before it does you any good. If swap is on an SSD all it will do is trash your SSD sooner. Buying more memory is cheaper. It puzzles me why an OS still sets up a swap partition nowadays. I guess old habbits don't die easely.
Offline Karel
« Reply #161 on: January 23, 2019, 07:18:55 pm »
If I remember correctly,  hibernating requires a swap partition with a size >= RAM.
Offline nctnico
« Reply #162 on: January 23, 2019, 09:29:12 pm »
That seems to be the case for Linux but you can disable using the swap space for swapping. However Linux won't touch swap space unless all memory is really in use. Windows always uses the swap space whether there is enough memory or not.
Offline HoracioDos
  • Country: ar
« Reply #163 on: January 23, 2019, 10:08:53 pm »
Thanks for the advice, but I don't care too much. My notebook has 8GB RAM and a low swappiness threshold = 10. It should start swapping when 90% memory is full and it never did.
swapon --show
NAME      TYPE      SIZE USED PRIO
/dev/sda4 partition 3,8G   0B   -2
I guess I could create a 1.6Gb swap file (20% RAM size) and save some disk space.
This is an article from REDHAT blog about swap.
https://www.redhat.com/en/blog/do-we-really-need-swap-modern-systems
PS: Swap and SSD Trim
From Arch docs: "If using an SSD with TRIM support, consider using defaults,discard in the swap line in fstab." but in other Arch document you can read "Note: Continuous TRIM is not the most preferred way to issue TRIM commands among the Linux community. For example, Ubuntu enables periodic TRIM by default [5], Debian does not recommend using continuous TRIM [6] and Red Hat recommends using periodic TRIM over using continuous TRIM if feasible. [7]"
From Debian Docs: "Alternatively, and often not recommended: Set "discard" mount option in /etc/fstab for the ext4 filesystem, swap partition, Btrfs, etc.
The "discard" options is not needed if your SSD has enough overprovisioning (spare space) or you leave (unpartitioned) free space on the SSD."
« Last Edit: January 23, 2019, 10:36:41 pm by HoracioDos »
Offline NiHaoMike
    • Facebook Page
« Reply #164 on: January 24, 2019, 03:38:58 am »
There's also the option of swap on zram.
https://en.wikipedia.org/wiki/Zram
Offline Karel
« Reply #165 on: January 24, 2019, 07:33:53 am »
Regarding SSDs and TRIM, I apply manually this command once a week:
sudo fstrim -av
It searches and takes care of all your partions on SSDs.
« Reply #166 on: January 24, 2019, 10:38:43 am »
For the external storage file systems, my choice was was between btrfs and ZFS.
Red Hat will discontinue further development for btrfs, while SUSE made btrfs their official choice.  This, and a few extra gimmicks listed as ZFS features made me commit to ZFS.
At first, reading about all ZFS can do, makes it intimidating.  Classical disk arrays can be complicated to setup or to operate.  On the contrary, ZFS was trivially simple to install, setup, and use:
# install zfs (Ubuntu)
sudo apt install zfsutils-linux
# create a zfs pool named 'WD8TB' on the disk /dev/sdc, and mount the new pool as /WD8TB
sudo zpool create WD8TB /dev/sdc
# create a new file system named '2019', it will be visible on the file system as /WD8TB/2019
sudo zfs create WD8TB/2019
That's all.  /WD8TB/2019 will be available for use like any other folder on the file system.  Creating a pool does not require disk partitioning and formatting.  All was ready instantly.
After copying the old files from the Windows 10 SSD to the new ZFS pool, I tested to see if I can read the ZFS pool disk on another machine (a Fedora 29).
# scan all disks for ZFS pools (scan will complete instantly)
sudo zpool import
# from the listed pools, import (mount) the wanted one in the home folder of user 'abcdef'
sudo zpool import WD8TB -f -R /home/abcdef/
# export (unmount) the pool 'WD8TB'
sudo zpool export WD8TB
And it was all working great, and very fast.
I'm sold for life to ZFS.  ^-^
Offline rdl
« Reply #167 on: January 24, 2019, 11:52:34 am »
If you ever need to set up a NAS, take a look at FreeNAS.
It uses ZFS and works pretty good. I've had it running for a couple of years now.
« Reply #168 on: January 24, 2019, 02:22:33 pm »
I am too, I love it and use it on a couple of 24-disk arrays at work. However it is out-of-tree, and as of kernel 5.0, has been explicitly dropped.
At home, I set up a 4-disk raidZ6 array using FreeNAS, and it works very well . FreeBSD takes a little getting used to for me. Bummer that RHEL dropped support for btrfs.
Offline Monkeh
« Reply #169 on: January 24, 2019, 02:35:26 pm »
Some symbols were changed. That's not the same thing as dropping support for, uh, something never supported to begin with.
« Reply #170 on: January 24, 2019, 02:44:14 pm »
True, but gkh and a couple of other kernel developers are actively trying to make life hard for ZFS-on-Linux devs. There's a workaround, but it comes with a significant performance hit.
Offline Monkeh
« Reply #171 on: January 24, 2019, 02:45:43 pm »
Again, reading too much into it - they just don't care if they cause problems.
Offline 2N3055
  • Country: hr
« Reply #172 on: January 24, 2019, 03:19:08 pm »
No, they don't give a damn about ZFS and will not care to support it... It's a licensing thing with Oracle/Sun.
begin quote :
This ZOL + Linux 5.0 issue stems from a set of functions used by this ZFS Linux port for vectorized file-system checksums no longer being exported. The kernel developers don't want to re-export the functionality since as Greg Kroah-Hartman put it, "my tolerance for ZFS is pretty non-existant."
Since that Phoronix article last week, Greg KH followed up on the mailing list with, "Sorry, no, we do not keep symbols exported for no in-kernel users." Longtime Linux kernel developer Christoph Hellwig also suggested users switch instead to FreeBSD if caring about ZFS.
Greg KH also commented on Tuesday that Oracle/Sun are the ones to fundamentally blame for the license by which they put out ZFS as for upstream kernel developers not caring about the support. "ZFS could be the best filesystem ever to grace this planet, that's fantastic, but given that the creators of that code placed it under a license that was specifically designed to not be compatible with Linux to prevent it from ever being used on Linux, well, you can see why I really don't care about it. Why would I?"
end quote
from : https://www.phoronix.com/scan.php?page=news_item&px=ZFS-On-Linux-5.0-Workaround
ediit: clarified quoting
« Last Edit: January 24, 2019, 04:08:27 pm by 2N3055 »
Offline Nominal Animal
« Reply #173 on: January 24, 2019, 03:21:24 pm »
Is that what
Quote from: gregkh
Sun explicitly did not want their code to work on Linux, so why would we do extra work to get their code to work properly?
says to you?  Funny.  I thought it says that Linux kernel developers are not willing to do extra work to get ZFS to work on Linux.
The Linux kernel codebase is one of the most actively modified codebase in the world right now.  Demanding that developers retain support for out-of-tree features is demanding that they tie one hand behind their back; that they freeze part of the development ... so that those who do not want to cooperate can keep up.  It is not "actively trying to make life hard", no matter how often it is repeated; it is just refusing to stop for stragglers.
« Reply #174 on: January 24, 2019, 04:17:37 pm »
but gkh and a couple of other kernel developers Is that what
Quote from: gregkh
No,
Quote from: gregkh
My tolerance for ZFS is pretty non-existant.
This is.
Read the full thread. Gkh turned an inlined function into a regular one, and while doing so marked it GPL-only. I don't see this as 'doing extra work' as much as giving the finger to modules that used that function. In any event, my plan is to switch to FreeBSD for my ZFS servers and I don't use it on workstations anyway (memory hog). We are going way off-topic again.
