I've completely given up on RAID systems.
* They add complexity in setup and management,
* Add an extra critical failure point - the RAID system hardware itself. If that fails the drives are typically unreadable via other means, and trying to replace the failed board or whatever can be hard &/or expensive.
* You typically can't just pull a drive out and read or copy it using standard hardware.
The simple rule I follow now is, can I read the drive in a cheap external USB HDD dock? Can I do complete file system duplications using treecopy utilities that copy all files without corrupting attributes like file dates, and will run to completion without throwing millions of errors and stopping without being restartable?
I won't use any system that doesn't allow that.
I keep all 'work' drives in removable trays, and never ever mix system/utility installs with work spaces.
With that, I can manage work backups as appropriate, using any old excess/found/salvaged drives or USB sticks (free), and all of the backup devices are readable as standard file systems on any PC. Such backups can take a long time, but I can run them on any spare PC without tying up my main work system.
Also when possible I format backup drives as FAT32, since as a last resort I can manually examine and patch FAT32, but NTFS is completely beyond such measures. For me, anyway. It sucks that now almost always filesets are too big for FAT32 drives.
Incidentally, many years ago, maybe around 2004, I tried a HD PCB & platter swap. The drive contents was fairly important. I'd decided a backup was way overdue, and was spending a few hours doing folder tree structure tidying, before backing up. Ha ha, big mistake inviting Mr Murphy to lunch. During that process the drive suddenly became a non-drive, ie not recognized by the BIOS at all, suggesting PCB failure. I had an identical working blank drive. Not sure if removing the PCB might break hermetic seal of the interior, I improvised a 'clean area' by using a large clear plastic bag, new from a stack and never 'fluffed up', so hopefully the interior was dust free. Cleaned the two drive exteriors with compressed air, slipped them and a screwdriver into the bag, taped surgical gloves onto the bag opening, and swapped the good PCB onto the bad drive. Result: now it was recognized, but couldn't read any data. I then tried a platter swap, so the single precious platter was in the body with known good PCB, heads and head-amp. That wasn't readable either.
On inquiring, I was told that (even then) the boards had head tracking calibration data in flash, and board or platter swaps never worked anymore. Never did recover the lost files.
