I have a TV that takes HDMI in the living room but want to use my laptop as the remote control, and to watch movies on the big screen. Could I put a raspberry pi on the TV through the HDMI out, then run VNC or similar program to make the lap top screen appear on the TV?
then play movies on the lap top and it will appear on the screen? Does sound go through VNC? Or will that require another solution, digital would be best rather then sending a wire to the TV, or some wireless audio set up.
Haven't used vnc in a long time would the screen refresh rate be quick enough if you are just going through the local network on your router?
Reason I don't just use the raspberry to watch movies on the TV is that things like Netflix won't work on it.
