Recently I have been checking this website trying to find examples of GLONAS antennas. Look at this article - it is simply fascinating!
http://www.spaceflight101.com/proton-m-block-dm-03-glonass-launch-2013.html.
"Taking a close look at the assembly log of the rocket, the commission discovered that the installation of the sensors was completed by a technician that was hired shortly beforehand. A supervising technician’s signature was also found in the log, however it is doubtful that an engineer familiar with the installation would not identify the error when performing a thorough visual inspection.
Experiments with actual Proton hardware have shown that it is possible to install the angular velocity sensors upside down. The
commission found that it would take a considerable effort by the technician to install the sensors incorrectly. The units are symmetrical in shape, but they have arrows that are supposed to point to the top of the vehicle to prevent an incorrect installation. Additionally, there are pins & corresponding holes that are designed to guide the technician to a correct installation. When installing the DUS sensors upside down, these pins would be misaligned with the holes. Installing the sensors that way would require the technician to apply force and
cause dents on the installation plate."
Imagine yourself as an engineer who designs systems knowing that people who will assemble them will be untrained, underpaid and will hammer things in by largest hammer they can find if it does not seem to fit for some reason.
And with all that it flies, almost all the time. I am taking my hat off.
