On several other SMF forums I participate on, they have enabled or added a "live feed" page which shows you a continuously updating list of what's being posted (usually 5~10 second updates using old refresh rather than AJAX requests though).
I couldn't see one active for EEVBlog but was wondering if there was any chance of having it added? I enjoy watching the live feeds because it gives me a chance to be exposed to topics I might not normally go looking for, helps 'widen' the horizons a bit
btw, I am aware the main landing page for this forum does have a 'snapshot' of the last N posts at the time of loading, though I'm not sure writing a 10~30 second wget + filter script would be too accepted "Somone's trying to DoS us!"
I use RSS for this purpose.
The link is at the bottom of every page - https://www.eevblog.com/forum/.xml/?type=rss
Didn't see that until I looked closer and highlighted the text at the bottom there ( not very visible due to the background ). Interestingly I only get a 403-Forbidden response from it.
I liked the AJAX/refreshing-HTML version because it was easy to just leave it as a tab or separate window on another screen when watching the forums, very easy to keep a finger on the pulse as it actually happened
Me to at the moment. I'm not sure if this is a browser thing or what. My RSS reader seems to be happy. Nut it may not know that this error has happened just yet. The last message I see in the reader is from 32 minutes ago. I will report if RSS feeder sees new messages.
Well, I use RSS for everything else, so it does not bother me. I have interests other that this forum
Ok, so forum pre-processor damages links. If you use my link, but copy and paste the text, not the link itself, it will work.
Use the second link, since the first one is already broken in the forum itself.
Let me try it this way - eevblog.com/forum/index.php?action=.xml;type=rss;limit=20;sa=news . Yep, just copy-paste this one.
And for completeness, link to all posted messages - eevblog.com/forum/index.php?action=.xml;type=rss . Be warned, it easily gets ~700 messages a day
Still seems to be working on Tapatalk.
There was a problem after the Christmas Day attack on the forum there is was still feeding (probably depending on your reader software) the photos from the deleted messages.
Seems to have worked here.
That's not too much of a concern. For me it's mostly I sit back with a cup of coffee, watch all the live feeds from the various sources, and just jump in if I see anything at the time that looks interesting; I'm not really trying to dig back through the proceeds of the day, just looking at what's active "now"
What's working? We are talking about RSS feed. The forum itself is working fine.
And what do you know. If you do this eevblog.com/forum/index.php?action=.xml;type=json , you will get JSON feed. Now all you need to do is a simple HTML5 frontend Nope, still XML, it is just browser does not recognize it as RSS anymore.
Here is a full list of things you can do.
http://wiki.simplemachines.org/smf/XML_feeds , so no JSON.
How often does the forum update the RSS feed? I noticed it's already about 20 minutes behind (I've tried refreshing a few times)
Not sure if this will work if you don't have an account with them; but this is what I'm talking about
https://www.rcgroups.com/forums/spy.phpIt's like a page dedicate to the data we see in the "Recent Posts" section on the main forum landing page, updated continuously within a few seconds of each post being submitted (the RCGroups one cheats a little, it polls every 20~30 seconds and then just feeds out the new posts ever couple of seconds to simulate a more 'real time' feel )
Instantly. RSS is generated dynamically on each request. Yor post is already there followed by a few others.
I don't think you can do anything like that. And I got dizzy after 10 seconds of watching RCGroups thingy.
