I'm not disagreeing with Thunderf00t's conclusion, but he was driving me nuts with his arguments in that video.
"Efficiency" in a rocket is not a measure of power to thrust conversion efficiency, it's
mass efficiency. A rocket that's good at power conversion (high thrust) is usually a good booster but a bad space drive.
There are two measures of note with rockets: Specific Power (Thrust over weight) and Specific Impulse (Propellant Mass Efficiency). The latter being a mere computational convenience to relate propellant mass to exhaust velocity. Ideally you want both high specific power and high specific impulse, but even conceptually, those are rare (e.g., Zubrin's bad-for-flying-cars nuclear salt water rocket
https://en.wikipedia.org/wiki/Nuclear_salt-water_rocket). Usually you get one or the other and choose your application based on that. Higher specific impulse drives obviously use more energy to generate a unit of thrust, but do so with less actual reaction mass. This allows vehicles like the Dawn space probe (electric ion rocket yielding well in excess of
10km/s for only 425kg of propellant in a 1200kg wet-mass vehicle!) to have a remarkably high deltaV with very little onboard propellant*. Albeit, all this at the cost of very low thrust (around 2000 day total burn time).
So a photon rocket, far from being "inefficient" in his words, has the theoretical limit of exhaust velocity (the speed of light) and hence, would be the most mass efficient design possible. Of course, apart from matter/antimatter reactions, there is little that can generate the power needed to take advantage of it in a useful way.
Likewise he kept saying the EM Drive "generates thrust" over and over, as a matter of comparison. No, it fricking doesn't. It's purest BS. No one would like that thing to actually work more than me, but it's a clear violation of the conservation of momentum. Likewise, the quantum vacuum it's supposedly pushing against (like all quantum fields at their vacuum expectation value, even the Higgs) is a
frameless phenomena. You can't push against it!
I will happily,
happily eat my shorts if the "effect" is anything other than experimental error.
*Note: if you run the numbers on Dawn, you find a max deltaV of 13km/sec, but that would be in running the propellant tanks all the way dry, and they didn't do that.
