Portugal 230V @ 16A (3.68 kW) maximum per outlet , but the code allows up to 8 outlets on the same 16 amp circuit, so, if you draw 16A on one outlet, you cant draw anything else on the remaining outlets who share the same breaker.
It a pitty though that most houses only have a 15A contract... The power company circuit beaker always flips before the individual circuit brakers do.
Here we have to pay monthly for what they call "Available Power" even if you don't use a single kWh! It's insane!
Then off course, on top of that Availability Tariff you pay per kWh used.
Here is the table:
Power Price (Month)
1.15 kVA 2.29€
2.3 kVA 4.03€
3.45 kVA 5.33€
4.6 kVA 6.92€
5.75 kVA 8.50€
6.9 kVA 10.09€
10.35 kVA 14.85€
13.8 kVA 19.60€
17.25 kVA 24.36€
20.7 kVA 29.12€
What other countries use this "available power" billing scheme?
