Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Flexible Friction Arm Holder
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Flexible Friction Arm Holder (Read 1254 times)
dbinokc
Contributor
on:
December 28, 2018, 11:01:37 pm »
Thought I would share this method for holding things while working on them.
The arms are called friction arms that are generally seen used for holding dial indicators or cameras.
I decided to put clamps on both ends to create a flexible holding arm support. The attached picture shows
a control panel from a surface grinder being held up by two arms while I work on it. I have also used this type of support to
hold circuit boards and hold cables and connectors in alignment for soldering.
Last Edit: December 28, 2018, 11:03:48 pm by dbinokc
Logged
t1d
Super Contributor
Country:
Re: Flexible Friction Arm Holder
Reply #1 on:
December 29, 2018, 07:14:28 am »
This looks like a superior bit of kit. Good job.
The arms are common. But, I haven't seen these clamps. Did you manufacture them yourself? If purchased, how about a link? Close up pictures, too, please and thank you...
Logged
LapTop006
Supporter
Country:
Reply #2 on:
December 29, 2018, 12:57:05 pm »
Also called Noga arms after
one company
Logged
dbinokc
Contributor
Reply #3 on:
December 29, 2018, 02:56:46 pm »
Do a search on ebay for friction arm clamp. Those will show arms that come with one clamp. You can find single clamps for sale as well.
Make sure you get an arm that has 1/4-20 threads on both ends.
A few more examples of use can be found in a post I made at
http://www.zenith.aero/profiles/blogs/starting-wing-skins-and-a-few-idea
Noga does make better arms, but are also more expensive. I use Noga for holding dial indications.
However the cheap arms work well enough for general work holding.
The only mod I made was that I had a problem with clamps not staying threaded on tight to the arm. I
used a little bit of loctite on the thread to keep the clamp on.
Logged
dbinokc
Contributor
Reply #4 on:
January 25, 2019, 01:23:59 pm »
I posted a video on youtube showing various ways I have used the clamps.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
