Author Topic: Freezing Speed of Hot Versus Cold Water  (Read 8747 times)
Offline bdunham7
Re: Freezing Speed of Hot Versus Cold Water
« Reply #75 on: February 25, 2022, 09:33:51 pm »
For this reason, experiments should not allow the sample to freeze. They should go from liquid at one temperature to liquid at another temperature.
That depends on what the purpose of your experiment is.  If you are testing the theory that one sample has a persistently different heat capacity than another, then OK.  Otherwise, and in the context of the OP's post and so on, that's probably not too enlightening.
