Author Topic: Fun for nerds  (Read 132603 times)
Offline RoGeorgeTopic starter
Re: Fun for nerds
« Reply #350 on: April 28, 2022, 06:33:05 am »
Homemade Solar-Powered CNC Engraver
Cranktown City
LASER Fusion engraver head!   8)
Re: Fun for nerds
« Reply #351 on: May 02, 2022, 04:31:28 pm »
You have a disconnected mains transformer, and with no load attached (open secondary).
At what moment in the sinusoidal mains voltage do you connect the primary to the mains?
a.  During a zero-crossing in the sinusoidal mains voltage.   :palm:
b.  During a peak voltage in the sinusoidal mains voltage.   :-+
Why?
ElectronicBits#10: Connecting inductive loads to the power line
Sam Ben-Yaakov
Re: Fun for nerds
« Reply #352 on: May 05, 2022, 10:47:21 pm »
The Bit Player | Claude Shannon | Father of Information Theory | IEEE Information Theory Society
Vaibhav Patil
Also found out about Claude Berrou's Turbocodes  8)
Near Shannon Limit Error-Correcting Coding and Decoding: Turbo-Codes
and discovered the voice of Teddy Grace:
« Last Edit: May 05, 2022, 11:10:21 pm by RoGeorge »
Re: Fun for nerds
« Reply #353 on: May 07, 2022, 07:49:19 pm »
Making Skin That Moves on Its Own
The Action Lab
It's alive!  :scared:
Re: Fun for nerds
« Reply #354 on: May 08, 2022, 07:36:25 am »
Creating 10 apps in Python with PySimpleGUI
Clear Code
Re: Fun for nerds
« Reply #355 on: May 12, 2022, 10:55:15 pm »
A Picture of the Milky Way's Supermassive Black Hole
Veritasium
Phased arrays are cool!  8)
Re: Fun for nerds
« Reply #356 on: May 16, 2022, 07:59:36 am »
Solar, low energy Curie motor
xofunkox-scientific experiments
A 0.2 mm alumel wire is attached to the circumference of a mica disc with thin copper wire. This alloy has a Curie point of 152°C and consists of 90.7% nickel, 3.1% manganese, 4.2% aluminum and 2.0% silicon. The low Curie point and the low-friction bearing allow operation with a 50 mm burning glass.
Source:  From the video description
« Last Edit: May 16, 2022, 08:03:29 am by RoGeorge »
Re: Fun for nerds
« Reply #357 on: May 17, 2022, 05:53:56 pm »
20W Fiber Laser Etching PCB Coil
DIY-Optics dot com
 :o
Re: Fun for nerds
« Reply #358 on: May 22, 2022, 06:39:36 pm »
TSP #207 - Teardown & Detailed Analysis of Qualcomm's 60GHz Multi-Panel Phased Array WiGig System
The Signal Path
 :o
Re: Fun for nerds
« Reply #359 on: May 23, 2022, 09:22:14 am »
Slowing The Speed of Light Down To 2 m/s—What Special Relativity Feels Like
The Action Lab
Re: Fun for nerds
« Reply #360 on: May 23, 2022, 08:37:09 pm »
3blue1brown is discussing this little innocent task:
"Find the number of subsets of {1, ..., 2000}, the sum of whose elements is divisible by 5."
Spoiler:
It includes complex numbers and a reference to the Riemann Zeta-function.
Re: Fun for nerds
« Reply #361 on: June 01, 2022, 04:01:00 pm »
Learning to Teleport
Buttered Side Down
Offline Ed.Kloonk
  • Cat video aficionado
Re: Fun for nerds
« Reply #362 on: June 04, 2022, 08:55:07 am »
iratus parum formica
Re: Fun for nerds
« Reply #363 on: June 04, 2022, 11:30:49 am »
Magnets are mad crazy, indeed!  ;D
Eddy current experiment with HDD components
Eddy current experiment with big Heat Sink
NETHERLANDS: BRITISH & DUTCH SCIENTISTS MAKE FROG FLOAT IN MID-AIR
Everything Is Magnetic! Moving Water With Magnets And Levitating Frogs
Then there is the Levitron, that apparently defies Earnshaw's theorem
Levitation with the Levitron
« Last Edit: June 04, 2022, 11:33:09 am by RoGeorge »
Re: Fun for nerds
« Reply #364 on: June 06, 2022, 12:59:37 pm »
Laser Decapsulation SSD CPU RAM
DIY-Optics dot com
 8)
namregpxp, 1 hour ago
How do you got such a machine?
DIY-Optics dot com, 1 hour ago
I bought mine from Cloudray. It's a 20W, 120ns fiber laser with 10kW peak power. You can process with it a variety of materials but mainly metals.. Marking, engraving, cleaning, cutting, heat treatment, decapsulation, color marking, PCB prototyping and a lot more
Re: Fun for nerds
« Reply #365 on: June 19, 2022, 07:53:18 am »
Dynamic balancing with a scope and small speaker
Matthias random stuff
The following users thanked this post: T3sl4co1l
Re: Fun for nerds
« Reply #366 on: June 23, 2022, 05:29:11 pm »
How Does The Wyrd Mechanism Work?
The Action Lab
 :o
Re: Fun for nerds
« Reply #367 on: June 28, 2022, 11:59:36 am »
OpenAI Codex Live Demo
OpenAI
 :scared:
Re: Fun for nerds
« Reply #368 on: July 02, 2022, 04:22:11 pm »
Mullard is showing how to produce vacuum tubes:
The following users thanked this post: chris_leyson, RoGeorge, arvidb
Re: Fun for nerds
« Reply #369 on: July 03, 2022, 03:12:30 pm »
Can Gyroscopes Provide Free Energy For The Planet?
The Action Lab
 :scared:
Offline Ed.Kloonk
Re: Fun for nerds
« Reply #370 on: July 04, 2022, 05:50:46 am »
Returning to the moon would be shocking.  :P
Re: Fun for nerds
« Reply #371 on: July 09, 2022, 01:29:31 pm »
A review of some games which are quantum physics based by Sabine Hossenfelder:
Offline Neper
Re: Fun for nerds
« Reply #372 on: July 09, 2022, 01:46:00 pm »
Here's how to make one at home:
Re: Fun for nerds
« Reply #373 on: July 10, 2022, 10:12:56 am »
Burning Pictures on a Compact Disc Surface
arduinocelentano
Source:    https://hackaday.io/project/186303-burning-pictures-on-a-compact-disc-surface
Sources:  https://github.com/arduinocelentano/cdimage
Offline Ed.Kloonk
Re: Fun for nerds
« Reply #374 on: July 10, 2022, 11:21:07 am »
That's really burning a disk image.
