Author Topic: Function Generator Waveforms  (Read 1463 times)
Online Ground_LoopTopic starter
« on: October 16, 2020, 08:13:02 pm »
Nearly every function generator I've ever seen has at a minimum sine, square, and triangle outputs with various modifications thereof.  I have a need for sine and square fairly often, but not once have I needed triangle where nothing else would do, especially at higher frequencies.  At lower frequency I can see a need for a ramp for timing or level comparison, but that's about it.  Please enlighten me to any other common uses for triangle  waves.
There's no point getting old if you don't have stories.
Online ledtester
Re: Function Generator Waveforms
« Reply #1 on: October 16, 2020, 08:21:58 pm »
With a triangle wave you can produce a PWM signal where the center of the ON state stays in the same place. This could be useful for certain applications and is called "phase-correct PWM".
« Reply #2 on: October 16, 2020, 08:24:44 pm »
Thanks,  I like that one.
Online nfmax
« Reply #3 on: October 16, 2020, 08:27:16 pm »
Providing input to characterise a circuit with a non-linear response, such as an optocoupler. Use a scope in X/Y mode, with the X axis showing the input voltage (the triangle wave) and the Y axis the output.
Offline bob91343
« Reply #4 on: October 16, 2020, 08:31:43 pm »
I use a triangle wave to create a sweep generator by using it to frequency modulate my signal generator.
Offline TimFox
« Reply #5 on: October 16, 2020, 09:11:29 pm »
The traditional analog function generator starts with a triangle wave, then derives the square and sine waves from the triangle.  A good analog generator can easily vary the symmetry of the original triangle wave to generate a ramp or non-square pulse waveform.
Offline S. Petrukhin
  • Country: ru
« Reply #6 on: October 17, 2020, 12:06:16 am »
Using a triangular wave allows you to check threshold elements.
And sorry for my English.
