Author Topic: Stock Electronic Image FAILS  (Read 426051 times)
Offline FireBird
  • Country: at
Re: Stock Electronic Image FAILS
« Reply #1425 on: May 02, 2026, 07:54:55 pm »
Did they really write "FERFECT" on the real meter?  >:D
Offline floobydust
« Reply #1426 on: May 02, 2026, 08:35:42 pm »
"FERFECT" Hilarious icon  :-DD
Are their furries in the Marketing Dept.?
Offline ebastler
« Reply #1427 on: May 02, 2026, 09:29:12 pm »
Nah. Here it is minus the AI fantasy:
There are perfect batteries?  :o
Sure, the ones holding 188% charge.
« Reply #1428 on: May 03, 2026, 07:25:53 am »
Multiple layers is basically a colour LCD, so not actually that uncommon  >:D
I mean multiple discrete LCDs, stacked. It wasn't colour filtered, and I'm not 100% sure but I don't think it had backlighting.
Online PlainName
« Reply #1429 on: May 03, 2026, 02:32:15 pm »
Yes, I knew what you meant but couldn't resist  :-//
I am sure I've seen that too, but I can't actually recall when or where.
Offline NiHaoMike
    • Facebook Page
« Reply #1430 on: May 03, 2026, 10:51:43 pm »
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline amyk
« Reply #1431 on: May 04, 2026, 02:53:41 am »
That's where the +12V pins on a PCIe slot are, so if that's a NCV probe they're calling an "inductor tester" (more like "inductive tester"), at least there's some truth to the image...
Offline NiHaoMike
    • Facebook Page
« Reply #1432 on: May 09, 2026, 02:39:17 am »
The following users thanked this post: PlainName, Gyro, kjr18, AVGresponding, SteveThackery
Online PlainName
« Reply #1433 on: May 09, 2026, 08:36:45 am »
I so want one of those.
Online free_electron
    • SiliconValleyGarage
« Reply #1434 on: May 11, 2026, 09:54:48 pm »
Avionics news magazine...
i'm going to start checking the knowledge of the aircraft techs before boarding ...
Offline TimFox
« Reply #1435 on: May 11, 2026, 09:59:45 pm »
I now refer to “conventional” current flow direction as “adult” current, opposite to the “baby” current in the series circuit article.
The following users thanked this post: free_electron
« Reply #1436 on: May 11, 2026, 10:08:05 pm »
careful now, next there will be people claiming that there are "holes" and that energy travels in wires ...
Offline temperance
« Reply #1437 on: May 11, 2026, 10:19:57 pm »
This sheds a completely different light on 911.
Offline Fungus
« Reply #1438 on: May 12, 2026, 09:52:44 am »
Not really on topic but I don't know where else to put it:
WTF???  :o
Offline Ranayna
« Reply #1439 on: May 12, 2026, 10:40:43 am »
Ages ago, i think that might actually have also been a Big Clive video, i saw a solar light that misused an IEC C13/14 connector for 12volts, to connect an external battery i think.
The adapter with the barrel jack seems to fit that particular use case  >:D
"Widow makers" seem to see something of a resurgence lately. I blame the high demand for generators, be they gasoline or solar.
Offline 44kgk1lkf6u
« Reply #1440 on: May 14, 2026, 03:20:50 am »
Some microscopes made by Vision Engineering use it for the 12 V lamp.  The lamp has the C13 commonly found on power cords while the power supply has the C14 commonly found on appliances.
