Author Topic: Help me identify a vintage electric component  (Read 5068 times)
Offline ballTopic starter
« on: March 02, 2021, 03:12:11 pm »
Hello. I found this odd vintage electric component in the middle of nowhere (on a mountain). It has two wire-wrap-like posts connected to six thick metal plates which are soldered/welded together by hand. There is matting between the plates of unknown fibrous material and it's housed in a clear green plastic shell that was clearly never sealed.
I thought at first maybe it was some weird custom battey but it isn't sealed. Then maybe a ballast resistor but then it's housed in plastic. What could it be? A sensor?
Offline bob91343
Re: Help me identify a vintage electric component
« Reply #1 on: March 02, 2021, 05:55:29 pm »
A home made capacitor maybe.
Offline MK14
« Reply #2 on: March 02, 2021, 06:05:55 pm »
It does look a bit like the internal bit, inside an electro-magnetic door lock. I.e. The internal 2 wire coil assembly part.
Online bdunham7
« Reply #3 on: March 02, 2021, 06:23:03 pm »
What are the plates made out of?  I would guess either battery of some sort or a moisture sensor.
Online Gregg
« Reply #4 on: March 02, 2021, 06:59:54 pm »
I would bet that it is a lead acid battery; or what is left of one.  The pointed electrodes are to penetrate a rubbery coating on a rescue strobe and the acid would be in a separate plastic bag or thin glass ampule to be broken and activate the cell.  Probably from an air force parachute harness or perhaps a weather balloon.
Offline Zero999
  • 0999
« Reply #5 on: March 02, 2021, 07:24:18 pm »
Beware, that fibrous material could be asbestos. Keep it together, in a sealed container and ask you local authority about disposal.
Offline CJay
« Reply #6 on: March 02, 2021, 09:16:23 pm »
Was thinking water activated battery from a weather ballon sonde but it looks *big* for that
https://en.wikipedia.org/wiki/Water-activated_battery
« Last Edit: March 02, 2021, 09:18:06 pm by CJay »
Offline amyk
« Reply #7 on: March 03, 2021, 01:10:52 am »
If the plates are lead then it is probably lead-acid.
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« Reply #8 on: March 03, 2021, 01:33:35 pm »
It does look a bit like the internal bit, inside an electro-magnetic door lock. I.e. The internal 2 wire coil assembly part...
No, there is nothing 'magnetic' like that, in the photo...
In digressing (as I'm apt to do! haha...), Mag-Locks always caused problems in a lot of systems!
They often have a 'built-in' alarm point sensor, and if the 'Mag' is de-energized, this causes an alarm, as if
the 'door' has been opened, even if it has not been opened. This sounds ok, but usually the system has
been programmed to cancel the remaining un-lock time after the door is physically pulled open. As a result,
they automatically re-lock about .5 sec after say an access card has been presented!!  Argh!!   >:(
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
Offline MK14
« Reply #9 on: March 03, 2021, 01:40:29 pm »
Don't worry, as the thread responses occurred. I also concurred (poem), that it seems to be some sort of battery. On re-looking at the photograph, much more carefully. I can see, the individual cells (presumably), with the plates, insulators/separators and filling material(s).
Somehow, a long time ago, I saw (possibly regularly), what I think (but could be wrong), was a similar looking electro-magnetic lock, thing (although it was much smaller, and only had one element section). Which is why I posted that suggestion.
It is probably easier to see and examine these items in real life, and maybe make some simple electrical tests and possibly see if a magnet is attracted to the metal(s), etc etc. To more accurately and quickly determine what it is.
tl;dr
This thread changed my mind (I wasn't sure, anyway), it does seem to be some sort of battery.
« Last Edit: March 06, 2021, 06:32:27 am by MK14 »
The following users thanked this post: GlennSprigg
Offline bsfeechannel
« Reply #10 on: March 04, 2021, 04:35:19 am »
Offline msuffidy
« Reply #11 on: March 04, 2021, 05:01:15 am »
Looks like a prisoner wood carving from Norman Cross Prison.
« Last Edit: March 04, 2021, 05:06:20 am by msuffidy »
Offline Cyberdragon
« Reply #12 on: March 05, 2021, 05:29:49 am »
If we go with the battery theory, it could be from a ballistic shell or missile, those have seperated electrolyte batteries that start from G-force when fired to activate instruments.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline BrokenYugo
« Reply #13 on: March 05, 2021, 06:12:31 am »
Mountains are sometimes shelled for avalanche control, but I kinda doubt they're using electronic fuzes for that.
Offline Cyberdragon
« Last Edit: March 05, 2021, 07:50:57 am by Cyberdragon »
*BZZZZZZAAAAAP*
The following users thanked this post: amyk, salbayeng, MK14, retiredfeline
Offline Cyberdragon
« Reply #15 on: March 05, 2021, 08:01:47 am »
Could also be the 6V filament battery, BB-51
BB-52 packaging and instructions
*BZZZZZZAAAAAP*
The following users thanked this post: Gregg, MK14, retiredfeline
Offline amyk
« Reply #16 on: March 05, 2021, 02:35:16 pm »
Great find!
Probably the 6V version as OP mentioned it has 6 plates.
More interesting information here (see page 39):
https://archive.org/details/TM11-430
I wonder if whatever it was powering is also somewhere nearby on that mountain...
The following users thanked this post: MK14
Online Gregg
« Reply #17 on: March 05, 2021, 09:35:51 pm »
The EEV-sleuth of the year award goes to Cyberdragon.  :-+  :-+
Great find!
« Reply #18 on: March 06, 2021, 01:23:24 am »
I had betted on a bathtub capacitor. LOL. After a while searching on the web I gave up. Really great find.
« Reply #19 on: March 07, 2021, 01:46:20 am »
Hey guys sorry I wasnt getting updates of the thread for whatever reason.
Wow, I didnt think it would be that old given the plastic housing! Thanks for solving the mystery!
Offline amyk
« Reply #20 on: March 07, 2021, 04:34:53 am »
https://en.wikipedia.org/wiki/Nylon#History was invented in the 1930s.
https://en.wikipedia.org/wiki/Poly(methyl_methacrylate)#History was also invented in the 1930s.
https://en.wikipedia.org/wiki/Polystyrene#History from the same time period.
https://en.wikipedia.org/wiki/Polyethylene_terephthalate#History was patented in 1941.
The first plastics are from the mid 19th century (celluloid etc.)
« Reply #21 on: March 07, 2021, 06:10:48 am »
I'm aware, but it wasn't exactly in common use
Offline Cyberdragon
« Reply #22 on: March 07, 2021, 06:39:42 am »
It was to an extent, and bakelite has been in wide use since the early 1900s, so has cellulose acetate.
*BZZZZZZAAAAAP*
« Reply #23 on: March 07, 2021, 06:41:36 am »
It clearly wasn't bakelite. Not sure why you would even bring that up
Offline CJay
« Reply #24 on: March 07, 2021, 08:40:42 am »
I think the point was made to show that plastics have been in common use for an *awfully* long time.
