Author Topic: High-speed USB isolator  (Read 64940 times)
Offline NiHaoMike
    • Facebook Page
Re: High-speed USB isolator
« Reply #50 on: September 10, 2019, 11:52:10 pm »
Now that the Raspberry Pi 4 has native 1G Ethernet, has anyone benchmarked it as a USB/IP bridge?
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline Lord of nothing
  • Country: at
« Reply #51 on: September 11, 2019, 12:09:01 am »
I use there  USB to Fiber Kit: http://www.studiofibersystem.com/
The legal import costed me a Ton of Fees ( :rant:) but the work.
I hope the will work with my ESXi to. I also have an Icron Set but the first one was broken (maybe a  cold Solder Joint) now I got an replacement I have to mount.
Well an "ordinary" Fiber Cable is the best thing because the length doesnt realy matter in a Home use. 10m, 20m, 30m,... 100m isnt any problem. And when someone destroy the Cable a new one dont cost me that much to replace.
I would never buy such Corning for SDR Stuff only if the USB Connection dont matter.
Made in Japan, destroyed in Sulz im Wienerwald.
Offline electronic_eel
« Reply #52 on: September 11, 2019, 07:11:40 am »
Interesting, thanks for sharing the link.
Which of exact product do you have?
Did you test if USB 3 Superspeed (5 GBit) and also USB 2 Highspeed (480 MBit) transfers work?
  • Country: at
« Reply #53 on: September 11, 2019, 10:15:42 am »
I check if the SDR work. And one SDR work now. If I find a good Signal Splitter I will connect more.
The should work do to the Claim of the Seller.
The seller told me my Product isnt on the Market right now.
Contact smugzhang@gmail.com and say you want the same as mine: PI No.: JM-USB-201905161
