Also if you do it right, failures are in my experience quite rare. Between furnaces and heat pumps I've installed about 10 of them so far starting more than 16 years ago. At this time every single one of them is still going strong, one I'm getting ready to replace just because I want something better and more efficient, not because there's anything wrong with it. The only problems I've had are the motor run capacitors in two of the heat pumps failed several years ago, that's a $10 part that is a common failure item. It's not rocket science, the equipment is not particularly complex and it is designed to last decades. All you really need is some attention to detail, do neat and tidy work and in the case of anything involving refrigeration, keep all parts of the hermetic system absolutely clean and dry. Handle it like a body you are doing surgery on, not a spec of dust or contamination inside. If you can follow instructions and do really nice quality silver soldered or brazed sweat connections on copper pipes chances are it will just work.
