It seems to be designed for Apple with magsafe. They have a ring of magnets already in the phone. This works quite strongly with magnetic holders like this.
However, I don't understand the comment about the metal ring. That might be used to convert a non-magsafe phone into one that will work (though not as effectively) but I don't see why you'd put it on a magsafe phone. I think the '24 hour' thing is because it's stuck on with an adhesive pad that gets stronger after a little while. 3M's VFD is like this.
Yes, this holder works exactly as you said!
It’s only for iPhones, but I was misled by the sentence: "It is compatible with most smartphones." I misunderstood it, I mean I didn’t realize that the extra ring had to be glued to the back of the phone in case it wasn’t an iPhone. I also thought that the extra ring somehow converted a non-MagSafe phone into a MagSafe-compatible one… I didn’t expect that the “conversion” was done using adhesive!
After this clarification, I tried placing the extra ring inside the rubber thin case of my phone, without actually sticking it on (see attachment), and in this way the holder works, I mean the magnetic ring is able to hold the phone securely.
So, does this mean that the only way to use these magnetic holders with non-MagSafe phones, like my Motorola, is to either stick the extra ring directly on the phone/case or place it inside its thin rubber case?
I guess there’s no point in looking for a holder with a stronger magnet, since non-MagSafe phones don’t have enough internal “metal” to be held magnetically, right?
