Author Topic: How do make a 3D Case? + How to Access a USB Device?  (Read 1354 times)
Offline Lord of nothingTopic starter
  • Country: at
« on: May 05, 2019, 08:59:21 pm »
Hi
I bought this Cam Module https://www.delock.de/produkte/729_Kameras/96371/merkmale.html a long time ago ( :scared:) now my Laptop is fast enough to do create something in 3D.
The Manual have some technical drawing: https://www.delock.de/files/25341.download
I would like create a "positive" Object where I could design the upcoming 3D part around that. I need to put some Metal Heatpipe on the Back for cooling.
I got this: https://www.zomei.com/ir-filter_p0117.html 2,5cm diameter IR Filter and I need to mount it infront of the Cam. The have some unknown screw.
What is the best 3D Planing and Printing Application for Win7?
Delock could not or the dont understand it to tell me how to access this:
 • Standard SCCB interface (I²C Bus)
I need to change the resolution for example to: 2592 x 1944.
Thanks
Made in Japan, destroyed in Sulz im Wienerwald.
Offline thm_w
  • Non-expert
Re: How do make a 3D Case? + How to Access a USB Device?
« Reply #1 on: May 06, 2019, 08:27:48 pm »
If your PC can run it then Fusion 360 and Cura:
https://www.autodesk.com/products/fusion-360/overview
https://ultimaker.com/en/products/ultimaker-cura-software
The second one is a bit more dependent on what machine you will use to print. But you can always select a built-in printer, and simulate the print, to get an idea of the time it would take, etc.
  • Country: at
« Reply #2 on: May 06, 2019, 08:38:01 pm »
Hi
I will a) lett it print from a Company or b) get it printed by a Hacker space if I find one.
I dont know what te use for printer now.
Offline thm_w
  • Non-expert
« Reply #3 on: May 06, 2019, 09:16:38 pm »
Hi
In either case you will need to output the 3D model STL file from your CAD program, and they will do the rest. Shapeways, dirty PCBs, your hackerspace, or others.
For something like the dirty PCBs SLA, they can basically print anything. But if its from a hackerspace (FDM), there are some limitations on to how you can design the part. If its a simple design I wouldn't worry about that right now though, it will probably be fine.
