Science fiction explores a lot of things. It may be a thousand monkey solution but the genre does come up with some real truths. I've long forgotten the author and story name of one of my favorites, but the plot has stuck with me. The gist of the story follows. Sorry about the lengthy version, if I were a better author I might not have been an engineer.
A senator is on a Jovian moon for a celebration celebrating a theoretical breakthrough proving that force fields have a limitation on the product of strength and duration. This is important because the inhabitants of Jupiter itself have discovered that life exists elsewhere in the solar system and are offended by the fact, promising to eliminate the problem. The large size of Jupiter assures that its military capability will exceed anything the rest of the solar system can do, but without force fields strength of materials limitations will keep the Jovians trapped on the surface of their planet. No pressure vessel can hold their surface atmospheric pressure in a vacuum.
At the celebration the theoreticians disparage technicians who have caused many explosions in laboratories experimenting with force fields, and touts his proof that force field pressure vessels are impossible. Everyone pats each other on the back and the celebration breaks up. The senators aid whisks him off for a ride home on a newly developed spaceship.
The senator quickly realizes that there is no visible hull to the space ship, the air is held in by a force field. The technician owner, who is missing an arm from an explosion during force field experiments, disparages theoreticians saying they have no idea of practical work. After his accident he quickly realized that the force field couldn't be left on too long, and devised a way to cycle it quickly, turning it off before it explodes, and turning it on before the air has a chance to expand meaningfully.
The message I take from this is that theory is very good about telling the limits and best application of known ways to do things. It may or may not define the limits of what can be done. And that neither technicians or theoreticians own all of the brains in the world.
